Author Topic: How easy is it to replace the rear bumper on a  (Read 1106 times)
« on: 22 May 2010, 23:37:34 »
Saloon car? tatty rather than shunted :D looked at a 2.5 TD CDX Mig today, may have walked without giving it much of a chance..... :-/
Re: How easy is it to replace the rear bumper on a
« Reply #1 on: 22 May 2010, 23:54:25 »
Dead easy. 2 torx screws on each wheel arch, one on the arc itself (where mudflap would go) one under the bottom. 4 or 5 plastic pop out clips under rear valance. Open boot and I think 5 screws under the oval screwcaps. Once removed, the ironwork is self-evident if you`re replacing that.
« Last Edit: 22 May 2010, 23:55:30 by RobG »
Agemo
  • Cleethorpes
  • Insignia
« Reply #2 on: 23 May 2010, 13:32:02 »
Yep, easy enough, your hardest job may be sourcing a replacement the right colour, or respraying.
« Reply #3 on: 23 May 2010, 21:18:33 »
As said... It's a doddle. 10 mins tops :y
    • 530D M Sport, 330i Coupe
« Reply #4 on: 23 May 2010, 21:21:51 »
Not so easy if it has a towbar though!
« Reply #5 on: 23 May 2010, 21:24:01 »
Depends what sort  :y
« Reply #6 on: 23 May 2010, 21:51:45 »
Sure I've had mine off and on OK with a shin breaker fitted :-/ :-?
Welung666
« Reply #7 on: 23 May 2010, 21:56:04 »
I can easily do 10 minutes with a fixed witter! Facelift is a torx, top edge in wheel arch. A torx at the bottom underneath at the wheelarch. 4 pop caps under bottom edge of the bootlid with torx screws beneath. Below are 2 plastic push pins, push the pin out of the centre and pull the square cap out. Pop the edges out at the wheel arch and they drop, then pul from the rear back an inch then lift up twisting to clear the pikey hook :y
« Reply #8 on: 23 May 2010, 23:09:12 »
Thanks chap's, was a black bumper so no problem with that :y
« Reply #9 on: 23 May 2010, 23:27:12 »
yup, easy peasy job! Worth having second pair of hands if you can source them  :y
