Author Topic: Multi ram removal for new intake??  (Read 1317 times)
mr ICE man
  • dolgellau wales
  • if it aint broke try and fix it
« on: 23 May 2010, 15:53:17 »
Hi all.I bought new air intake system off egay last night from a ex police car so he said.it gets rid of multirams and goes straight from filter to engine.it has maf senser etc but wondered of I'd just been done over as he said would improve performance?am I a fool? ::)
« Last Edit: 23 May 2010, 15:53:51 by si0797 »
scream if you want to go faster!!!
duggs
  • Felixstowe
    • BMW 3.0 Sport
Re: Multi ram removal for new intake??
« Reply #1 on: 23 May 2010, 15:55:52 »
I'm certainly no expert...but sounds a bit fishy to me.
Never seen ANYTHING regarding running without the Multirams.
« Reply #2 on: 23 May 2010, 15:57:24 »
Think you've been had mate  :(
jonathanh
  • coventry
« Reply #3 on: 23 May 2010, 18:01:19 »
sorry but i cannot see that it is any use at all.  There is no way that VX would incur the extra cost of fitting a multiram system over a couple of basic pipes if they could get away with it.  the multiram system is there for a reason.  Mr Plod did not AFAIK modify it.  Sadly i suspect you've got a DIY bodge
« Reply #4 on: 24 May 2010, 11:02:49 »
There are boxes like this which appear to be what you're describing:
http://www.mantzel.de/neu/Power-Resonator
Quite an expensive metal box, that one. :o
The thing you have to appreciate about the multiram system is that it allows the length of the intake tract to be adjusted to engine RPM.
At low RPM you want a long intake tract for best power. At high RPM you want a short intake tract. The multiram system goes some way to achieving this by splitting the intake tracts for each bank of the engine and providing two valves to join these tracts together, one in the plenum and one in the u-shaped duct behind the rad.
This gives the best compromise between low RPM and high RPM grunt, and gives the engine a very flat torque curve from as low as 2500 RPM up to the red line.
Most aftermarket tuners probably don't understand the finer points of what the system is achieving and see it as restrictive, hence these products exist.
Yes, you can probably get marginally better power at the top end by replacing the standard setup with a shorter duct but you lose the ability to tune it to low RPM running.
In a heavy car like an Omega I would regard pull at low RPM to be just as important, if not more, than getting the highest possible "pub figure" at 6K RPM.
But, you have the box. It won't do any harm to give it a try and see for yourself. Can always chuck it back on Ebay if it disappoints. :y
