Author Topic: screen wash  (Read 1467 times)
moggy
  • hartlepool
    • vauxhall omega 3.0 elite
screen wash
« on: 25 May 2010, 16:22:50 »
Hi all just found a problem with my omega,the screen wash wont work.The windscreen wipers do the set 4 wipes but no screen wash,i have done the obvious filled the screen tank and checked the fuse.But i cant hear the pump working any help much appreciated Dean :y
Re: screen wash
« Reply #1 on: 25 May 2010, 16:29:47 »
Pull the pump out of the bottle, it's just a push fit. If the pump had been heard to run I would have suggested the classic problem of a blocked filter - it's part of the grommet you've just pulled the pump out of. As you can't hear anything, I'd suggest that the ump is fubar'd  :-/ but to prove it, try putting 12 volts across the terminals - doesn't matter which way round while testing. New pattern pumps aren't expensive on eBay. Single outlet for saloons & twin for estates  :y
moggy
  • hartlepool
Re: screen wash
« Reply #2 on: 25 May 2010, 19:28:18 »
Thanks Andy b pulled the pump out no obvious pr-obs,pushed it back in bobs your uncle.The only thing is it's really,powerful on the drivers side,and crap on the passengers side.Poked the holes out still crap passengers side :y
Re: screen wash
« Reply #3 on: 25 May 2010, 19:31:34 »
A quick, cheap, easy fix.  :y
Any leaks underneath the bonnet, they can rust out causing reduced flow to one side.  :-/
moggy
  • hartlepool
Re: screen wash
« Reply #4 on: 25 May 2010, 19:39:11 »
Andy no obvious leaks but,there seems to be some kind of connector and wires.Underneath the nozzle pass/side that are not connected :-/
Zuffenhausen
  • Telford, Shrops.
    • 2000 2.5TD CD Estate
    • Walks and Waggy Tails
Re: screen wash
« Reply #5 on: 25 May 2010, 20:14:54 »
The wires are for the nozzle heaters that come on with the heated rear screen.
