Author Topic: front tyre wear  (Read 1650 times)
karlus 693
  • Isle of Wight & Torquay
front tyre wear
« on: 26 May 2010, 14:25:20 »
Hi Just a quick one, The off side front tyre keeps wearing out on the inside edge (if you know what i mean ) I have had it tracked twice once at ATS and also Nat tyres. But its just started scrubbing my new rubber  >:( am i over looking something?
Just had new wishbones fitted but has been traked since
alank46
  • South Devon
    • 3L Elite Estate 1996
Re: front tyre wear
« Reply #1 on: 26 May 2010, 14:44:08 »
Hi
Tracking alone is no earthly good.  The front suspension needs proper alignment, most garages cannot do this.  Do a search on alignment, there has been lots of discussion on this forum.
Alan
karlus 693
Re: front tyre wear
« Reply #2 on: 26 May 2010, 15:30:53 »
Thanks Alan
Goonybird
  • Northampton
  • Shouldn't have gone to Specsavers
Re: front tyre wear
« Reply #3 on: 26 May 2010, 15:45:18 »
Sorry to Hijack this thread  :-[
but did wishbones in March for MOT. Both tyres now worn badly on inner edge.
Just had partworns put on today as temporary fix which gives me about 1 or 2 months to sort it. At least this garage admitted they can't do it!
Can anyone recommend somewhere local to Northampton that is able to set the front geometry?
many thanks
stef
« Last Edit: 26 May 2010, 15:45:55 by goonybird »
Have owned: Opel Manta A 1900 Auto Berlinetta, Opel Manta B 2.0 Auto Berlinetta, Vx Royale Coupe 2.8 Auto, various non Vx, Skoda Superb 130tdi currently Omega 2.5CDX - now Octavia vRS WRC
duggs
  • Felixstowe
    • BMW 3.0 Sport
Re: front tyre wear
« Reply #4 on: 26 May 2010, 16:16:40 »
Would advise for "poster" to get wishbones checked.
Might need replacing. Certainly was the answer on mine when i had exactly the same problem.
Was amazing that the inside of the tyres could get so warn down so quickly....not least the fact that I didn't notice. Drove to Austria and back, at speed  ;) ;) with virtually no tread on the first 50mm. Naughty !
« Last Edit: 26 May 2010, 16:17:07 by duggs »
vic
  • Aldershot (Hampshire)
Re: front tyre wear
« Reply #5 on: 26 May 2010, 18:29:46 »
Accept WIM may be too far for you to travel but you really need to identify an outfit like these guys. They have the latest kit and do know how to use it. Cost £60 to OOF members. Good luck.
VC:y
http://www.blackboots.co.uk/contact-blackboots.php
Re: front tyre wear
« Reply #6 on: 26 May 2010, 20:33:32 »
ah, here we are again, very common problem on the omega unfortunately, well not so much a problem as unknowing garages not knowing or caring that the omega shocks are adjustable for camber.
Usual approach applies, rectify any suspension faults, full geometric set up at wheels in motion or the like, THEN fit new tyres.
Problem is your set up is now so far out the tyres will be ireperably worn causing handeling issues until they are replaced. Its possible to replicate the old camber settings by measuring the wheel rim to shock distance prior to dismantling. Or set the camber to a tad short of vertical with a spirit level on level ground, purely to minimise tyre wear. Then drive the car to a set up company.
Max camber if the shocks are just bolted up can approach something like minus 3 degrees. Enough for the tyre sidewall to rub the shock body and destroy a tyre to the wire in 3k.
Best camber setting is WIM's recommended -1°10 minutes. Merely setting up to "in the green" "as factory settings" can give similar poor results, as the tollerances from vx are far too wide.
hth.
« Last Edit: 26 May 2010, 20:39:39 by chrisgixer »
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: front tyre wear
« Reply #7 on: 26 May 2010, 22:26:25 »
Hi karlus, chesham in bucks is a bit far i know but it would be worth every penny and time to go to Wheels in motion and see the man on this issue, Tony Bones is his name and this forum cant reccomend him enough. Camber is what needs to be set up or you will ruin every tyre you fit to your car.
Gary. :(
Jaguar XJ6
Page created in 0.012 seconds with 14 queries.
