Author Topic: Can you increase the V6 tickover?  (Read 1471 times)
maximoke
  • Daventry/Northampton
« on: 28 May 2010, 21:18:46 »
Hi there.  I am now finally driving my car having completely redone the top end.  It drives lovely, although needs tracking and wheel balancing doing.  What I would like to know is can the tickover be adjusted from the standard 500 -550 rpm to something like 650 - 700 rpm?  Without reprogramming the ECU?  Thanks
Re: Can you increase the V6 tickover?
« Reply #1 on: 28 May 2010, 21:23:08 »
.....  What I would like to know is can the tickover be adjusted from the standard 500 -550 rpm to something like 650 - 700 rpm?  Without reprogramming the ECU?  Thanks
No. But why would you want/need to?  ;)
maximoke
« Reply #2 on: 28 May 2010, 22:21:35 »
Mine actually ticks over at 500rpm and it's a little bit lumpy, I am confident that it would not stall at that level but it's a bit sweeter at 650rpm, plus I've never had a car with such a low tickover.
« Reply #3 on: 28 May 2010, 22:22:48 »
Try cleaning out your idle air control valve, there's a maint guide on it. That should help  :y  :y
  • Auckland
    • Mazda MPV
« Reply #4 on: 28 May 2010, 22:23:44 »
Alternative answer: yes. - Switch the A/C on.
« Last Edit: 28 May 2010, 22:24:41 by andyh »
« Reply #5 on: 28 May 2010, 22:27:19 »
 ;)  ;)  but that's cheating!  :y
tidla
  • solihull
« Reply #6 on: 28 May 2010, 22:37:28 »
too many andys round here to keep up. :)
« Reply #7 on: 28 May 2010, 22:42:28 »
If it feels lumpy with A/C off, you should investigate it, rather than hide it. Or turn A/C on ;D
Only possible to raise rpm via tech2. Don't be tempted to do via butterflies - it will be lumpy as hell.
« Reply #8 on: 29 May 2010, 01:41:44 »
tracking is no good either, needs full geometric set up after rectifying any suspension issues, dont fit new tyres until then. 5 stud balancer is more accurate than the usual cone balancer, if your having balancing issues.
