Author Topic: Won't turn over now got new DIS pack!  (Read 1002 times)
Varche
  • middle of Andalucia
    • Golf Estate
« on: 29 May 2010, 13:31:10 »
Disconnected battery and replaced DIS pack this morning. Put back together correctly I think but reconn battery , turn ign key and rev and speedo needles "flicker" and lights on dash dim and that is it. I suspect after a fortnight or more of being stood the battery has lost its charge. So borrowed a neighbours charged up yellow jump start pack and the same. (I have used it in the past to good effect)
Have I forgotten something?
Do I need to put the immobiliser code in? The SAFE on the MID I just assumed meant radio etc
Starter motor jammed?
Earth strap loosened during DIS change.?
It is at times like this that a manual would be an advantage!
Edit - Think I have found the problem. All the fuses in the secondary aux fuse box(on top of the pos terminal on the battery) were loose. Pushed all home and now turns over but battery needs recharging.
« Last Edit: 29 May 2010, 14:54:15 by olive »
eliteomegaman
  • Bolton, Lancashire
  • if it aint broke dont fix it....
Re: Won't turn over now got new DIS pack!
« Reply #1 on: 29 May 2010, 14:45:43 »
Hola! my friend  :y
U left a comment on my topic about my misfire which thankfully has now all been sorted as it was down to my dispack!!
Would love to help u but unfortunately i am not mechanically minded. I'm sure one of the many 'experts' will soon be able to help u out of your predicament  :)
Good luck & take care  :y
« Reply #2 on: 29 May 2010, 22:11:56 »
Mid code saying "safe" is just the stero. :y
