Author Topic: Engine management  (Read 2699 times)
spudmariner
  • Portsmouth, Hampshire
Engine management
« on: 27 May 2010, 15:05:18 »
I'm pulling my hair out now. The engine management light isn't coming on at all and the car won't start even though it was fine the other day when the light was working. Plenty of fuel in there but no spark & no fuel coming up. Any ideas pleaseas money is now very tight. Thanks. Graham
Welung666
Re: Engine management
« Reply #1 on: 27 May 2010, 15:08:37 »
Have you had the dash out to check/swop the bulb?
spudmariner
« Reply #2 on: 27 May 2010, 15:13:26 »
Yes, had the dash out and swapped bulb with one that definitely works and still no go. Thanks
Welung666
« Reply #3 on: 27 May 2010, 15:18:42 »
Are all the large fuses next to the battery still all OK?
spudmariner
« Reply #4 on: 27 May 2010, 15:53:36 »
yes, all checked and ok. thanks
Welung666
« Reply #5 on: 27 May 2010, 16:45:49 »
Hmmm, a baffler! Perhaps a friendly PM to Mr Wood and ask nicely for the aid of his Tech2 services would help get to the bottom of it?
spudmariner
« Reply #6 on: 27 May 2010, 16:57:18 »
cannot find mr.wood under PM....thanks
« Reply #7 on: 27 May 2010, 17:01:43 »
spudmariner
« Reply #8 on: 27 May 2010, 17:13:47 »
Thanks very much. Have sent PM and hopefully get to the bottom of it. Graham.
« Reply #9 on: 27 May 2010, 17:49:41 »
Hi Graham,
Pm received. :y
What exactly do you see on the dash when you turn the key to the ignition position (I.E. what lights come on, do any flash, and do any extinguish after a few seconds)?
My thoughts are that if the EML doesn't come on at all either the engine ECU or the dash is probably not getting power.
That narrows things down quite a bit. Will have a look at the wiring diagrams later and see what exactly.
« Last Edit: 27 May 2010, 17:50:43 by Kevin_Wood »
spudmariner
« Reply #10 on: 27 May 2010, 18:07:26 »
Abs light and EML, not working, all others are ok.
Thanks
« Reply #11 on: 28 May 2010, 00:39:24 »
Thanks
Hmm. OK. Will have a think. :y
spudmariner
« Reply #12 on: 29 May 2010, 01:49:46 »
Thanks for all your help. It turned out that the large 30 amp fuse by the battery had blown but right up in the corner & hard to see. Car now running but cutting out on braking more times than not. I'll look at that later but at least I can get to work now. Thanks again.
same #same#
  • south yorks
  • dont blame me im dyslexic
« Reply #13 on: 29 May 2010, 01:58:41 »
sounds like a eletrical problem if some thing has blown one of them fuses witch one had blown??
spudmariner
« Reply #14 on: 30 May 2010, 04:30:53 »
It was the green 30 amp fuse. I cleaned all the contacts & touch wood apart from a poor tickover, its pulling like a train now
