Author Topic: Cracking drivers door  (Read 3409 times)
bert
Re: Cracking drivers door
« Reply #15 on: 31 May 2010, 08:05:18 »
i had this problem on my old vectra it turned out to be the door stay which snapped in the end from its weld it was a pain trying to keep door open after that just had to live with it  :(
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
« Reply #16 on: 31 May 2010, 10:37:04 »
Hi, on similar topic, I shall be checking my washers, as the drivers door stay has totally ripped out !!! (whether due to washer probs, I'll never know.) :(
However, as I am left with a gaping hole (all the gummage was laying in the bottom of the door).... is this repairable. I am assuming the repair kit shown in links, is just to strengthen existing fixings.
Is a repair kit available to mend a total failure ???
Or is it a case of finding someone with the knowhow ????
Thanks in advance :y
« Reply #17 on: 31 May 2010, 10:52:16 »
My driver's door had ripped out the fixing for the door stay completely and has been temporarily/permanently  ;) fixed with a reinforcing plate either side of the remnants of the door skin. failing that you need to weld more metal in or replacing the section of door that's failed ie ....
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
« Reply #18 on: 31 May 2010, 10:58:51 »
Hi Andy,
Thats a brilliant pic of plate  :y....I assume by the 'numbers' thats a VX replacement part....again assume two needed, or is it a kit.
THAT is something within my capabilities, whereas welding is not.  :y
« Reply #19 on: 31 May 2010, 11:04:59 »
Hi Andy,
The plate shown is the bit that's failed, and if you'd met the criteria at the time & Vauxhall had repaired your car, this is the plate they'd have removed from your car & re-welded in. I bought the plate with the possibility of welding it in my car, but the reiforcing plates were enough to 'fix' it. There is a part number for the reinforcing plates somewhere, probably in the guide & are far easier to use. You'd have to remove the door & drill spot welds out fit the pressing I've shown .......  :y
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
« Reply #20 on: 31 May 2010, 11:08:35 »
Great stuff mate, appreciated  :y
Annoying thing...I spent many years in the engineering trade, and could have had my engineers/welders make any parts AND do it for free  :( :(
« Last Edit: 31 May 2010, 11:09:17 by terbert1 »
« Reply #21 on: 31 May 2010, 11:17:02 »
if I still worked for Hall's Mentholyptus I'd have had access to all the gear and been able to do it myself. Hey ho  :-/
