Author Topic: Cracking drivers door  (Read 3398 times)
i260
  • Newport, South Wales
« on: 16 April 2010, 20:36:44 »
Really bad cracking noise as I open and close the drivers door - been gradually getting worse. Something to do with the hinge / stays but cant identify - have tried spray etc but sounds more than that. Any ideas?
Saab 9-5 Aero 260ps
Re: Cracking drivers door
« Reply #1 on: 16 April 2010, 20:38:15 »
there is a little plastic ring/gasket that sits in between the bracket no the chassis and hinge, cost about 10p! Not got part number to hand though
MickAP
  • South Derbyshire
« Reply #2 on: 16 April 2010, 20:47:11 »
Part no 90462823  bushing
They cost me 27p each (one per door stay) from Pentagon VX last month
Mick :y
  • Online Online
« Reply #3 on: 16 April 2010, 20:49:26 »
But it could also be the door skin ripping where the stay bolts to it. You can buy a reinforcing plate (or make one) to help, preferably before it rips out altogether.
« Reply #4 on: 16 April 2010, 20:52:31 »
Good point, depends how far its gone. Seen DTM weld some back in place, might be worth OP posting up a photo  :y
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #5 on: 16 April 2010, 21:39:15 »
:y Yep, try the plastic ring/bush. Mine would give an almighty crack. Changed the bush and the problem was solved.
VX mainstealer said it wouldn't cure it and I would need the £36.00 (plus VAT) 'door strap' kit.  ::)
« Reply #6 on: 16 April 2010, 21:45:56 »
 :o :o :o :o
« Reply #7 on: 16 April 2010, 21:47:30 »
If you hadn't changed the little plastic washer they would be right !!! eventually the doorstrap bracket would have failed ...  :(
  • Online Online
« Reply #8 on: 16 April 2010, 22:08:14 »
It's not the check strap that's normally the fault though Nige, it's the part of the door it bolts to that fails/rips.
« Reply #9 on: 16 April 2010, 22:32:04 »
Thats what I thought I said ....    :)
  • Online Online
« Reply #10 on: 16 April 2010, 22:33:15 »
Oh!  ::)  ;)  ;)  ;)
Zuffenhausen
  • Telford, Shrops.
    • 2000 2.5TD CD Estate
    • Walks and Waggy Tails
i260
« Reply #12 on: 17 April 2010, 22:47:52 »
Top stuff guys - looks like one of these solutions will do the trick - will get back and let you know what the prob was.
Saab 9-5 Aero 260ps
i260
« Reply #13 on: 30 May 2010, 23:05:01 »
Hey all - the washer was the culprit. 10 mins and a few pence and the drivers door sounds like new again!
Can't see any signs of damage to the old bit though! Oh well...
Saab 9-5 Aero 260ps
webby23
  • Nottingham
  • MV6
« Reply #14 on: 30 May 2010, 23:15:38 »
This is one of the few repairs even I can do myself......
