Author Topic: Whats this for? Rod behind climate controls  (Read 1754 times)
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
« on: 31 May 2010, 14:20:26 »
Was removing an old hands-free kit and had to take the climate control panel off to detach the phone cradle.
Found this lying on top of the wiring loom not attached to anything - it was quite badly bent, I've straightened it out.
Looks like a link rod to me, but where should it go and what does it do?  Climate seems to work fine.
Anyone know?
Cheers,
Stephen
« Last Edit: 31 May 2010, 14:33:40 by sjc »
  • Online Online
Re: Whats this for? Rod behind climate controls
« Reply #1 on: 31 May 2010, 14:22:52 »
err?
I give in ........ what is it?  ;)  ;)  ;)
presumably an operating rod for heat/direction flaps
sjc
  • Alloa, Scotland
« Reply #2 on: 31 May 2010, 14:27:48 »
err?
You were too quick!  I hadn't finished - was just checking the photo was showing ok.
 ;D
Omegafantasy
  • Oslo, Norway
« Reply #3 on: 31 May 2010, 14:30:09 »
As far as I can remember, this rod connects left and right side flap for the defroster (only one servo for this).
Edit: I have to stop idling when writing posts :p
« Last Edit: 31 May 2010, 14:31:08 by omegafantasy »
1995 Omega 2.6 V6 Estate ("fresh" engine) Drives like a 2-litre. Grr! Gettin' dusted by a 1.8 auto Cav..
1991 Omega 3000-24v (major rust job)
(Interested in buying Vauxhall emblems/grille for my V6)
sjc
  • Alloa, Scotland
« Reply #4 on: 31 May 2010, 14:37:20 »
Is it easy/possible to put back, I couldn't see any obvious place for it to go so I'm guessing it's away up the back somewhere   :'(
Omegafantasy
  • Oslo, Norway
« Reply #5 on: 31 May 2010, 14:52:00 »
I'm not sure how easy it is. A mate of mine put it back together (as it was his car). I can try to find some instructions for it when I get home, it might be visible in the Haynes book.
sjc
  • Alloa, Scotland
« Reply #6 on: 31 May 2010, 16:13:44 »
That would be magic, cheers.  Will check the Haynes book, but going by how utterly deficient their description/pictures of how to remove the climate control fascia panel is, I'm not overly optimistic!  It has a photo of a hand going into the radio hole but not one of the release lever for the panel - WTF!!!
(found a pic on here of course  :y)
« Last Edit: 31 May 2010, 16:18:43 by sjc »
