Author Topic: Fans not coming on properly  (Read 1715 times)
« on: 31 May 2010, 20:00:03 »
After abit of a run yesterday, I stopped at the shop and was in and out.  Got back in turned the ignition on and the temp was at 100!! :o :o I could hear the fans running so started up and sure enough the temp dropped back so headed home.
When I got home I turned the engine off and could hear fans running, but when I turned the ignition off the fans stopped, when I popped the bonnet I saw that it was only the fan at the rear running and not the two at the front!
Any ideas peeps?
same #same#
  • south yorks
  • dont blame me im dyslexic
Re: Fans not coming on properly
« Reply #1 on: 31 May 2010, 20:03:15 »
sounds about right if all fans going can flatten the battery as draining just to cool down rad.
« Reply #2 on: 31 May 2010, 20:47:12 »
Font two are for air con
« Reply #3 on: 31 May 2010, 21:00:16 »
pretty sure it's the single rear fan for aircon. The front two can run slow or fast which would suggest that they're both for engine cooling.
« Last Edit: 31 May 2010, 21:00:40 by Andy_B »
Richgm
  • Tamworth
« Reply #4 on: 31 May 2010, 21:27:39 »
My front 2 don't run if the aircon is off
Noli nothis permittere te terere
« Reply #5 on: 31 May 2010, 21:43:40 »
it could always be me that's wrong ..... again ::) :y
« Reply #6 on: 01 June 2010, 09:54:09 »
Until recently, all three fans worked.  Now its just the rear fan working and only when the ignition is on.  :(
So when I turn off after a run there's nothing cooling the rad and its getting hot!!  :o Its a new rad and I don't want it to go pop!!!  >:(
I've checked the fuses and all good, could it be a dodgy relay?
