Author Topic: LSD's  (Read 1110 times)
Sixstring
  • Lydney, Gloucestershire
LSD's
« on: 01 June 2010, 10:38:13 »
Have seen a few threads about these lately.....what do they do, and is there any advantage in me fitting one to my 3.0 elite estate?
Re: LSD's
« Reply #1 on: 01 June 2010, 10:48:33 »
LSDs respond differently to a normal diff when one wheel starts to slip. They transfer torque to the wheel that still has traction whereas with an open diff the torque is always split equally meaning that the spinning wheel keeps spinning, and the car loses traction.
They are great in situations such as when cornering hard where the inner rear wheel is unloaded. You can still get some power down whereas with an open diff the inner wheel will just spin.
On the downside, when the rear end of the car breaks away under power with an LSD, it will be much more prone to stepping out, since both rear wheels will generally let go at once, so they can be more of a handful to drive, especially in the wet.
For normal road use, I'd say they don't make a lot of difference, except for the odd moment when "pressing on". Their ability to deal with lack of traction in terms of not getting stuck in mud, snow, etc. is partly made up for by the traction control system on a V6, which can achieve a similar, although not as effective, result by braking the slipping wheel.
Sixstring
Re: LSD's
« Reply #2 on: 01 June 2010, 10:50:25 »
Thankyou, kevin, I assume from that fitting a LSD to mine would be a waste of time and money?
Mike.
Re: LSD's
« Reply #3 on: 01 June 2010, 10:57:36 »
I've driven a few x-plods and my old 24v Senator had one, they are good fun! Wet round-abouts i had a lovely power slide, you can really chuck it about put big smile on your face!  :)
Re: LSD's
« Reply #4 on: 01 June 2010, 10:59:45 »
Mike.
Depends on you, and the way you drive, really.
They can make fast exits from "T" junctions much more satisfying but if most of your driving is on reasonably grippy tarmac and you don't find yourself hitting the traction control then it's probably not worthwhile.
Bear in mind that a lot of LSDs fitted by the Police are lower geared than the factory open diffs, which might be an issue.
Re: LSD's
« Reply #5 on: 01 June 2010, 11:06:55 »
Mike.
Make them rapid off the line though!
