Author Topic: Air Intake Sensor  (Read 1027 times)
neil3l
  • Ipswich,Suffolk
Air Intake Sensor
« on: 02 June 2010, 13:43:17 »
EML light came on after cambelt change, check on tester shows air intake sensor, new one has made no difference, will reset but light came straight back on same fault, any clues?
andyc
  • Norfolk
Re: Air Intake Sensor
« Reply #1 on: 02 June 2010, 14:38:17 »
Had the same problem when i first got my car. Some before me had been playing and got the plug to the intake ram switch and the air temp switch the wrong way round.
if its a pre face life car the air temp sensor should be a white/grey colour connector and the ram valve connector is black
If they are the wrong way round just swap back and the light should go out
Cheers
Andy
« Last Edit: 02 June 2010, 14:38:51 by andyc »
Thetford. Norfolk
« Reply #2 on: 02 June 2010, 14:38:40 »
What year is it?
On early units its possible to get the multiram plug and air temp sensor plug mixed up.....the multiram plug should be the one on the longest bit of wire.
neil3l
  • Ipswich,Suffolk
« Reply #3 on: 02 June 2010, 15:55:18 »
Result, thanks
