Author Topic: cylinder head torque settings  (Read 1387 times)
Ken T
  • Stockport
« on: 25 May 2010, 14:16:03 »
Does any one know the torque settings for the cylinder head and cam bearings on the 2.2 ?
My car has been running a bit under par for some time, and its been steadily getting worse, power seems down, and now missing at tickover and loosing 4 pints of water in 60miles  :'(
I couldn't get her to run properly on LPG, I kept getting missfiring on pot 1 at around 40-50mph, but thought it was just not enough gas getting in. However its now using a lot of water, I can't see any other leaks, and the missing at tickover suggests its a bit serious.
I'm going to do the head gasket tonight/tomorrow. Hopefully the head hasn't warped. Is there any else I should check while the head's off ?.
Ken
Welung666
Re: cylinder head torque settings
« Reply #1 on: 25 May 2010, 14:27:33 »
Should think it'll be the same as the 2.0 4 pot which are:-
Head bolts in 4 stages:-
1) 25nm
2) 90º
3) 90º
4) 15º
Cam bearing bolts 8nm
Cam Cover bolts 8nm
« Last Edit: 25 May 2010, 14:27:50 by Welung666 »
gsizoli
  • Hungary
« Reply #2 on: 25 May 2010, 14:58:54 »
Haynes says:
25NM-90'-90'-90'-15'
Which is the true 4 or 5 stages??
« Last Edit: 25 May 2010, 14:59:28 by gsizoli »
gsizoli
  • Hungary
« Reply #3 on: 03 June 2010, 21:30:15 »
Anybody?
TIS also mentions 25NM+90+90+90+15 but I've bought ERLING head gaskets but it mentions 90' only 2 times.
So which method should I use?
« Reply #4 on: 03 June 2010, 21:50:08 »
1) 25nm
2) 90º
3) 90º
4) 15º
Cam Cover bolts 8nm
Think you have a stage missing Lee.... on the petrols, it's
25nm
90deg
90deg
90deg
optional 15deg tolerance turn
