Author Topic: Getting Frustrated  (Read 5549 times)
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
Re: Getting Frustrated
« Reply #15 on: 01 June 2010, 20:44:44 »
I thought they had to be pressed in with some big press thing ? :-[
Proz
« Reply #16 on: 01 June 2010, 20:46:36 »
you can measure the gap between shock and wheel rim prior to dismanteling to replicate the old camber setting, wise to check it after though.
General rule imo
judder or wobble on the brakes is brake issue
judder or wobble in a certain speed range is wheel balance, try 5 dtud balancer
judder or wobble random at any speed or condition is wishbones, just to confirm (as if it was needed) what Mark says.
With squeel, is the shimmed pad fitted on the piston side? if yes try either playing with swapping pads with shims to one side or other, or both shimmed pads to the squeeky wheel, or take the shims of the old pads and stick them onto the 2 non shimmed pads, assuming they are trade club pads.
IME nothing makes any lasting odds to sqeeling brakes except pads with decent shims either riveted or clipped on the back of the pad material.
It doesnt happen under braking .... i fitted the pad with the backing to the piston side .
« Reply #17 on: 01 June 2010, 20:48:06 »
If replacing like with like then yes.
Hence the sudgestion to use polybushes.
If you bash/cut the old rubber out of the centre of the bush and then use a hack saw to cut the sleeve of the bush (from where you have removed the rubber i.e. inside to out) then the metal insert will push out easily.
Poly bushes can be inserted without a press  :y
Hence its more DIY friendly and actualy not to impossible to do without even removing the whole wishbone assembly
« Last Edit: 01 June 2010, 20:49:22 by Mark »
Proz
« Reply #18 on: 01 June 2010, 21:07:30 »
Mmm still sounds a bit daunting to a person who isnt good with spanners  ;D ... is there a guide on here for it ... I'll go and check  :y
« Reply #19 on: 01 June 2010, 21:29:20 »
General rule imo
So thats option 1 out then, and its not wheel balance, so that only leaves wishbones, as said by The Master.
Could try swapping the shimmed pads around, make sure the pads sit flat in the caliper and on the piston and non piston side, do you have the old pads/shims?
« Last Edit: 01 June 2010, 21:31:20 by chrisgixer »
Proz
« Reply #20 on: 01 June 2010, 21:35:59 »
General rule imo
No i dont have the old ones but they didnt have any kind of backing on them at all .
« Reply #21 on: 01 June 2010, 21:43:42 »
Not really necessary, just gotta be good with a hacksaw ;D ;D
Proz
« Reply #22 on: 01 June 2010, 21:57:47 »
Im just trying to picture what replacing the bush is like ... i'll try and get underneath it this weekend and maybe get a better picture of whats involved  :y
Proz
2woody
  • Northumberland
« Reply #24 on: 02 June 2010, 11:12:20 »
have you tried the steering box damper ?
2woody
  • Northumberland
« Reply #25 on: 02 June 2010, 11:13:05 »
« Last Edit: 02 June 2010, 11:13:38 by 1417_stuart_grange »
Proz
« Reply #27 on: 02 June 2010, 14:05:07 »
No i havn't ... where is it and what am i looking for  :y
2woody
  • Northumberland
« Reply #28 on: 04 June 2010, 09:11:01 »
on top of the steering box - adjustment screw and locknut.
make sure that the steerign linkages are pointing straight ahead when you want to go straight ahead, then loosen the locknut and screw in the adjuster by a very small amount. Road test. Repeat until the steering JUST won't self-centre and slacken very slightly.
expect up to 30 adjustments and road-tests until you've got it right.
  • Auckland
    • Mazda MPV
« Reply #29 on: 04 June 2010, 15:59:01 »
I don't think it is a steering damper :-/
If the Omega uses a worm and roller steering box then the adjustment screw pushes the roller against the worm and should be set so that free play is just perceptible when straight ahead.
If it is done up tight enough to make the steering tight then it will be exerting an immense force on the steering quadrant and could cause it to break and cause total loss of steering :o
