Author Topic: Getting Frustrated  (Read 5546 times)
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
Getting Frustrated
« on: 01 June 2010, 19:13:12 »
Hi
Ok bare with me on this because im going to try and give as much information as i can on my problem ...
Steering wheel wobble between 45-55 mph typical of wheels needing balanced , however it doesnt happen all the time .
Its only occasionaly .
Its through the steering and not through the car .
I can accelerate slowly from 40-60 and it doesnt happen then the next time it does ... there is no pattern to it and its getting on my nerves .
I have had a new GM steering idler and trackrod ends , drop links , GM brake discs in case one was warped .... however the brakes now squeel  :-/.
I have even got new wheels and tyres and had them balanced and checked at three different places but it still shows up now and then . Every time they say the wheels are fine and dont need balanced but re-do them anyway .
It also did this with the old wheels ... i got new ones because i thought maybe one was bent .
There are no knocks etc that i can hear from the suspension :-/
The car when wobbly feels horrible to drive between these speeds but feels fine under and over these speeds .
The hubs were spotlessly clean before the new discs went on .
So what am i needing to do beore i go mad with it ... it has just passed the mot with no advisory so does that mean the wishbones are fine ?
I dont understand how its there one time then not the next on the same strech of road ...Obviously something that rotates is running out of true but what do i check next before i unleash the matches  :'(
Sorry for the long winded story but im getting desparate now to have a nice wobble free drive .
Thanks
« Last Edit: 01 June 2010, 19:14:34 by Mark38 »
same #same#
  • south yorks
  • dont blame me im dyslexic
Re: Getting Frustrated
« Reply #1 on: 01 June 2010, 19:22:35 »
have you tryed driving down a track road with so nice bumps, found mine it was a damaged rubber on the anti-roll bar could not see a fault with it but bumps found it and changed it  only cost 50p.
« Reply #2 on: 01 June 2010, 19:24:06 »
Wishbones......check them with a bar on the rubbers.
Proz
« Reply #3 on: 01 June 2010, 19:29:34 »
I did look at them but they look fine but yep at the cheap price i might change them  :y
Proz
« Reply #4 on: 01 June 2010, 19:31:00 »
So am i just looking for some movement in the bushes ... i dont really know what to look for  ... i might just get some Lemforders anyway  :y
« Reply #5 on: 01 June 2010, 19:38:17 »
Movement....there should be some when reasonable force is applied...if there is a lot then they are goosed.
Squealing brakes =  poor fitting generaly
Proz
« Reply #6 on: 01 June 2010, 19:39:16 »
Then i will have the problem of trying to find somewhere up here that can do the geometery after new wishbones ...  :'(
Proz
« Reply #7 on: 01 June 2010, 19:41:06 »
I made sure everything was cleaned up before i changed them .. only thing i didnt have was copper grease although i have it now so hopefully if i put some on it should stop  :y
same #same#
  • south yorks
« Reply #8 on: 01 June 2010, 19:42:35 »
did mine with 2 long bits of wood from back wheels, got it level with the back, :y
« Reply #9 on: 01 June 2010, 19:45:53 »
If not already present then file a leading and trailing edge on the pads
Proz
« Reply #10 on: 01 June 2010, 19:48:26 »
They were GM pads and do have a chamfered leading and trailing edge already  :y
« Reply #11 on: 01 June 2010, 19:50:39 »
Ok, one option on your front bushes (assuming they are goosed) is to drop the front of the wishbone down and remove the old bush.
Then  fit poly bushes and re-assemble.
This will have very minimal impact on your geometery
Proz
« Reply #12 on: 01 June 2010, 20:02:45 »
Mmmm i think that is way out of my league and capabilities  :-/
« Reply #13 on: 01 June 2010, 20:09:46 »
you can measure the gap between shock and wheel rim prior to dismanteling to replicate the old camber setting, wise to check it after though.
General rule imo
judder or wobble on the brakes is brake issue
judder or wobble in a certain speed range is wheel balance, try 5 dtud balancer
judder or wobble random at any speed or condition is wishbones, just to confirm (as if it was needed) what Mark says.
With squeel, is the shimmed pad fitted on the piston side? if yes try either playing with swapping pads with shims to one side or other, or both shimmed pads to the squeeky wheel, or take the shims of the old pads and stick them onto the 2 non shimmed pads, assuming they are trade club pads.
IME nothing makes any lasting odds to sqeeling brakes except pads with decent shims either riveted or clipped on the back of the pad material.
« Reply #14 on: 01 June 2010, 20:09:50 »
Lol, so, jacking up and removing one bolt.....using a hacksaw to cut through the metal sleeve of the old bush and then inserting the new bush and replacing the single bolt is a bit to much?
Thats what it takes but I appreciate that not all have the tools etc to do it  :y
