Author Topic: Immobilizer  (Read 1366 times)
sport
  • Stoke on Trent
Immobilizer
« on: 01 June 2010, 20:13:32 »
Hi the car will bump start and runs fine if ther is a bad earth on the ecu will the engine run and are there 2 parts to the immobilizer
Re: Immobilizer
« Reply #1 on: 01 June 2010, 21:37:31 »
Sorry, I could not understand that sentence...  ...maybe better description/punctuation needed  :-[
Re: Immobilizer
« Reply #2 on: 01 June 2010, 21:40:35 »
If immobiliser is faulty car won`t start so that can be ruled out. What exactly are the symptons you`re trying to describe :-?
tidla
  • solihull
Re: Immobilizer
« Reply #3 on: 01 June 2010, 21:43:09 »
Hi,  the car will bump start and runs fine. if there is a bad earth on the ecu, will the engine run. are there 2 parts to the immobilizer?
« Last Edit: 01 June 2010, 21:43:48 by tapper888 »
sport
  • Stoke on Trent
Re: Immobilizer
« Reply #4 on: 02 June 2010, 21:46:50 »
Hi the car will bump start and runs fine.
If ther is a bad earth on the ecu will the engine run,
and are there 2 parts to the immobilizer.
Think i sorted it, it may be the ignition barrel.
« Last Edit: 02 June 2010, 21:51:22 by sport »
sport
  • Stoke on Trent
Re: Immobilizer
« Reply #5 on: 04 June 2010, 21:13:10 »
[size=12]Sorted my starting problem, put a wire from ignition to starter, now starts every time[/size]. :)
Page created in 0.277 seconds with 16 queries.
