Author Topic: Brake Pads  (Read 3372 times)
Re: Brake Pads
« Reply #15 on: 04 June 2010, 20:11:24 »
I would recommend skimming them.......
I wouldn't   by the time you've got to the stage where you might be thinking about a skim, it's afair bet that the discs will be near their min thickness anyway. You've have to fork out for machining (I tried to skin a pair at work, all clocked up in the lathe etc etc ........ they were a mile out when fitted - a local machinist is unlikely to be able to do better that I did)
Buy a new pair .... they're around £100 for discs & pads from vauxhall on Trade Club
Don't buy pattern, unless you want to repeat the process
« Last Edit: 04 June 2010, 20:11:49 by Andy_B »
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
Re: Brake Pads
« Reply #16 on: 04 June 2010, 20:49:18 »
what are the best pad and discs to buy?
Re: Brake Pads
« Reply #17 on: 04 June 2010, 20:55:13 »
Vauxhall's on Trade Club  ;)  ;)
OK their pads might not be the best, but they're certainly up to the job. Gixerchris will tell you that the 'proper' Vauxhall pads are hands down the better pad .... but they're £75-ish a set!  :-?
plym ian
  • Plymouth, Devon
Re: Brake Pads
« Reply #18 on: 04 June 2010, 21:57:13 »
cheers bit pricey will look into them :)
Re: Brake Pads
« Reply #19 on: 04 June 2010, 22:00:30 »
Ordinary Trade Club pads are good enough for the rest of OOF mortals though  :y ;)
