Author Topic: Noise starting from hot  (Read 1015 times)
omegadave1
« on: 03 June 2010, 13:35:01 »
Hi
I hope some one can me i've have a 2002 Omega 2.2 Petrol  CD done 60,000 miles one owner full service history i've had it for the last six months with no problems it has know developed a strange problem after driving for half an hour or so if you Switch off the car and start back up again there is a horrible noise that is coming from the starter motor gearbox area. Has any one any idea what it could be ?
Dave
Welung666
Re: Noise starting from hot
« Reply #1 on: 03 June 2010, 14:07:13 »
Define 'horrible noise'??
omegadave1
« Reply #2 on: 03 June 2010, 17:13:33 »
I would say its a clancking sort of noise
omegadave1
« Reply #3 on: 05 June 2010, 12:03:57 »
Hi
Have been told the fault could be the dual mass flywheel does any one know if these are fitted to a 2.2 petrol ?
SJKOO01
« Reply #4 on: 05 June 2010, 16:29:07 »
It's difficult to try and diagnose 'strange noise problems' by written description, and also noises can often come from a different place than you think there actually from ?.
When you say you 'switch off the car and start back up again there is a horrible noise, is that where by as soon as you switch off then back on again, or if you switch off, leave it for say 5mins, then start again (if you understand what I mean ?).
Are you sure that it's coming from the starter motor gearbox area ?.
Can you test if the starter motor is secure to it's mounting, or is it loose ?.
Any other information you can give us about the noise, or other symptoms ??.
« Last Edit: 05 June 2010, 16:29:49 by SJKOO01 »
« Reply #5 on: 05 June 2010, 20:48:53 »
as above need a bit more detail really....
Is it only at idle? Or with revs, does it go when moving, or changing gear? Does the sound change depending on revs? Does it do it in neutral or in gear.
