Author Topic: door hinge pin help  (Read 1200 times)
elite col
door hinge pin help
« on: 06 June 2010, 21:08:52 »
you know the centre hinge when opening door that lets how far you open door?
my drivers one is missing the pin,it has a bolt in it instead and makes 2 massive clicking noises when opening and closing
is this the part i need? or is this for the 2 main hinges
thanks in advance
http://cgi.ebay.co.uk/Vauxhall-COMBO-OMEGA-ZAFIRA-MERIVA-ETC-DOOR-PIN-NEW-/370376796084?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item563c2d67b4
Re: door hinge pin help
« Reply #1 on: 06 June 2010, 21:13:08 »
thanks in advance
that's one of the 2 main door hinge pins
You should have a bolt (M6) in the door stay  :y
have you looked at the leading edge of the door, where the stay should bolt to? Poke your finger in there VERY CAREFULLY and feel for sheared/snapped metal  :y There's a how-2-do in the maintenance section showing you what you need to repair your door.  :y
« Last Edit: 06 June 2010, 21:15:31 by Andy_B »
MickAP
  • South Derbyshire
« Reply #2 on: 06 June 2010, 21:50:50 »
I've recently replaced my two front door stay bushes.
If that's the problem, cracking when opening the door then this is the guide.
http://www.omegaowners.com/forum/YaBB.pl?num=1161105965
Mick :y
elite col
« Reply #3 on: 06 June 2010, 21:54:49 »
great guys thanks il check it out
