Author Topic: Good Morning At Wim  (Read 1332 times)
Craig_R
  • Watford
Good Morning At Wim
« on: 03 January 2008, 13:25:37 »
Went back to See Tony This Morning to get my Fine tune done and I Told him that I was Pulling to the Left and he Looked at a Few Things and said my Left Wheel was slightly back from the right, So It Looks Like the Guy who Fitted my Wishbones did it wrong and knacked it when fitting it Grrrr
But while Tony was tapping in to his Computer i had a Good old pull on stuff under the car as its not often you get your car on Ramps without a mechanic any How found that my Idler Arm Has Vertical Play only a small amount but still play, so pointed this out to tony he said this could be the reason for the left wheel being out so ill be changing that quick sharp Oh The Joy  ;D
Also On my was back home popped into VX to see if they would refund my money on the crankshaft sensor i bought when i got the camshaft sensor also and it ended up being the Cam snsor that was knacked The Guy said Yep no problem we can do that for you which i was suprised at. Just had a look at the recipt and the guy refunded me for the Cam sensor at 47 quid instead of the crank sensor at 35 quid Bouns :) :) help towards the cost of a new idler Arm  :y :y
Craig
« Last Edit: 03 January 2008, 13:26:11 by CraigR »
Mod's
[To be Fitted]Reverse Sensors
Re: Good Morning At Wim
« Reply #1 on: 03 January 2008, 13:31:36 »
result!  :y
Craig_R
  • Watford
« Reply #2 on: 03 January 2008, 14:40:45 »
Must be the First Time I have Ripped Off Vx instead of them ripping me off lol
« Last Edit: 03 January 2008, 14:41:01 by CraigR »
Mod's
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #3 on: 03 January 2008, 16:44:15 »
Thats a result craig, will have to phone tony for my fine tune as it's due, i understand that tony is busy at the mo which is good as he was a tad concerned that he was doing the right thing going on his own,  well tony if you read this spot on mate, see you soon. :y
Jaguar XJ6
Craig_R
  • Watford
« Reply #4 on: 03 January 2008, 16:50:17 »
I said i would phone him once i fit the idler arm to see if it solves the problem so he can collect data from problems.
fingers crossed it ill solve my problems.
He was busy, when my car was on the ramps 2 lexus cars pulled up for their setups, I think they were from the lexus Club.
Mod's
ffcgary1
  • Mitcham,Surrey.
« Reply #5 on: 03 January 2008, 17:57:56 »
Tony pointed out to me when i had my set up done that i needed the idler arm replacing due to wear. replaced and then took it back to have the toe in/out set. He knows his stuff does tony and i am not supprised that more and more clubs are using his services. :)
Jaguar XJ6
