Author Topic: Open boot when central locking and keyfob do not w  (Read 1875 times)
voncardew
« on: 06 June 2010, 20:41:43 »
As the owner of a 2.6CDX Omega (52) reg is there a way of opening the rear boot lid when  the key fob remote does not work nor does the release button on the bottom right of the stereo unit.   [smiley=sad.gif]
Re: Open boot when central locking and keyfob do not w
« Reply #1 on: 06 June 2010, 20:43:46 »
Have you tried holding the button in for 3 or five seconds? :-/ :-/
« Last Edit: 06 June 2010, 20:44:00 by Lizzie_Zoom »
tidla
  • solihull
« Reply #2 on: 06 June 2010, 20:44:28 »
drop the back seats, pull the handle :)
saltyone
  • warrington cheshire
  • my babys
    • 53 2.6cdx /06 xj6 2.7tdvi
« Reply #3 on: 06 June 2010, 21:01:28 »
tin opener's on offer at tesco 99p well every little helps  ;D
"friends help you move....REAL friends help you move bodies"
eliteomegaman
  • Bolton, Lancashire
  • if it aint broke dont fix it....
« Reply #4 on: 06 June 2010, 23:53:29 »
The only way the button 'inside' works is when the key is 'removed'  :y
As for the button on the remote control - i've the same problem but i'll try what Lizzie has suggested & push me knob in for 3-5 secs then it should pop up ............
and no funny remarks thankyou  :o ;D ;D
tidla
  • solihull
« Reply #5 on: 07 June 2010, 00:06:10 »
doh!
« Reply #6 on: 07 June 2010, 08:57:08 »
If the release has failed electrically/electronically, lower the rear seats, there is a manual release lever in the top of the bootlid so you can open in an emergency.
As for the button by radio working, depends on age - earlier facelifts need the key out of ign, later ones just need button press and hold for about 3s.
eliteomegaman
« Reply #7 on: 07 June 2010, 11:51:56 »
Mine is the earlier model so only opens from the inside with the key out  :(
As for the remote i've held the button in on the remote for about 10secs but nothing - cud be the selonoid?  :-?
tommycon
  • oldham
« Reply #8 on: 07 June 2010, 19:08:38 »
mine did this and i had to open it using the manual release, after checking the the catch i found that it was very loose so tightened it and works every time now, just thought.
« Reply #9 on: 07 June 2010, 19:10:52 »
The favourite is a broken wire in the 'flexi ish' loom to the boot.
But drop the seats and pull the latch to get in (unless you have a stupidly large LPG tank  ;D)
tommycon
  • oldham
« Reply #10 on: 07 June 2010, 20:23:44 »
forgot to mention when pressing key fob or dash button i could hear the solenoid kicking in very very faintly.
once you have managed to open the boot press the plunger button  at the side of the lock and press the boot release button and if it was just loose like mine you will hear the solenoid activate.
Page created in 0.011 seconds with 14 queries.
