Author Topic: Help I'm locked out!!  (Read 1901 times)
mr ICE man
  • dolgellau wales
  • if it aint broke try and fix it
« on: 07 June 2010, 18:40:32 »
Hi all my wife just dropped my key and the fob has broken the remote part is now not paired and they key won't turn the lock in door or boot!which I didn't know!!how the he'll do I get in it without breaking a window????
scream if you want to go faster!!!
hoofing it
Re: Help I'm locked out!!
« Reply #1 on: 07 June 2010, 18:45:40 »
wd40 and brute strength shound do the trick don't be frightened of breaking the key :y
Shrek
  • Fife , Scotland
« Reply #2 on: 07 June 2010, 18:47:06 »
Yeah you have to be brave and try and force it using the key. It will go eventually  :y
"My Naff Code Reader" and OBD2 readers available .
mr ICE man
  • dolgellau wales
« Reply #3 on: 07 June 2010, 18:47:12 »
Will try that but I'm not sure the key is the same as the it doesn't work in the boot either!going to call previous owner!9
hoofing it
« Reply #4 on: 07 June 2010, 18:51:47 »
if you locked the doors with the fob and deadlocked it breaking a window won't help as you won't be able to lift the button
mr ICE man
  • dolgellau wales
« Reply #5 on: 07 June 2010, 18:57:37 »
Surely I can then put my key in igntion and reprgramme the fob!?
mr ICE man
  • dolgellau wales
« Reply #6 on: 07 June 2010, 19:24:25 »
Woo I'm in!how do I reprogram my key??
Shrek
  • Fife , Scotland
« Reply #7 on: 07 June 2010, 19:32:29 »
Im not sure but if you turn ignition to position II and press the buttons i think that resyncs it ....you might be best to check the immobiliser chip is still in the position in the key   :-/
« Last Edit: 07 June 2010, 19:33:35 by Shrek »
Shrek
  • Fife , Scotland
« Reply #8 on: 07 June 2010, 19:35:32 »
Does the fob still work or did the fall break something inside .
Do the led's on it work ?
hoofing it
« Reply #9 on: 07 June 2010, 21:04:39 »
:y :y :y
mr ICE man
  • dolgellau wales
« Reply #10 on: 07 June 2010, 21:32:48 »
All sorted!my days what a panic!!!!
Shrek
  • Fife , Scotland
« Reply #11 on: 07 June 2010, 21:48:40 »
Nice one ... :y
Page created in 0.015 seconds with 14 queries.
