Author Topic: Success!!!  (Read 1435 times)
Jukeboxnut
  • West Sussex
    • 2004 2.2 auto CDX estate
Success!!!
« on: 07 June 2010, 20:57:56 »
I have been having problems with the heater blower fan speed for a while now with only 2 speeds (i.e. dead slow or flat out with nothing in between regardless of any manual selection and I have tried the reset procedure with no success.
After reading a few posts here I was convinced that a new resistor was needed which is very expensive even secondhand but being a tightwad I thought I would try a simple fix.
Luckily I am a very skinny seven stone weakling so it is easy for me to scramble about in the passenger footwell and after removing the trim panel under the glove box I could just see the plug the fits in the resistor.  It was a fiddle but I managed to touch the wires in the plug and give them a push as they felt a bit loose.
A quick test run and the fan is working perfectly on all five speeds again what a result for only five minutes work and no money spent!
If any one else has a problem with their heater fan speed this is worth trying, although if you have big hands you may have to remove the glovebox for access.  It appears that the contacts in the plug can work loose over time, it is upside down which is not ideal.
Radar
  • Berkshire
    • Elite 2.5 Auto
Re: Success!!!
« Reply #1 on: 07 June 2010, 21:02:53 »
Nice one, good result :y
Shrek
  • Fife , Scotland
Re: Success!!!
« Reply #2 on: 07 June 2010, 21:21:25 »
Excellent result  :y
"My Naff Code Reader" and OBD2 readers available .
MickAP
  • South Derbyshire
Re: Success!!!
« Reply #3 on: 07 June 2010, 22:51:28 »
How do you do that?  will try on mine :y
Mick ;)
« Last Edit: 07 June 2010, 22:52:02 by MickAP »
Re: Success!!!
« Reply #4 on: 07 June 2010, 23:02:54 »
Mick ;)
If your car has climate control you hold off and auto in for approx 5 seconds , It then resets the all the climate  :y
acura
  • Lancashire
Re: Success!!!
« Reply #5 on: 08 June 2010, 06:23:18 »
I had a problem where my climate control just stopped working, no display, nowt! My lad managed to get his hand in and find a loose plug, snap together and Hey-Presto! fully working aircon. I thought it was lousy VX build but seems these plugs do work loose. A satisfyingly cash-free fix  :y
From Consul 375 to Omega, 30 cars and counting.....
