Author Topic: Steering wheel removal  (Read 2934 times)
Hannah Judes Dad
    • the misses round the bend
« on: 07 June 2010, 21:41:37 »
What is the best way to remove a steering wheel ? I must be missing something as mine won't pull off and before you ask yes I have removed the 22mm nut off the spindle before you tell me otherwise. ::)
Re: Steering wheel removal
« Reply #1 on: 07 June 2010, 21:47:28 »
You're best to leave the nut on by a few threads till you've released it off its taper to preserve your smile  ;D  ;D. They say a sharp clout from behind will shift it, but I have a puller I made years ago
Hannah Judes Dad
« Reply #2 on: 07 June 2010, 21:50:30 »
Sounds like I could do with that puller! and thanks for the advice about keeping my smile (even with my child scaring face it might come in useful one day) ;) :y
« Last Edit: 07 June 2010, 21:50:52 by hannahjudesdad »
« Reply #3 on: 07 June 2010, 21:54:07 »
Easiest way for me was as Andy says, but I gave it a few clouts at the 9 o/c and 3 o/c positions. Once off then you can fit your flylead Simon :y
tidla
  • solihull
« Reply #4 on: 07 June 2010, 21:57:08 »
grab it at "9" and "3" and rock it/give it some.
(on the old astras there was two oval shaped cut outs in the boss for a puller)
Hannah Judes Dad
« Reply #5 on: 07 June 2010, 21:59:11 »
Thanks Rob,any particular idiotting hitting tool or just the heaviest thing I can find?  ;D
« Reply #6 on: 07 June 2010, 22:06:03 »
The Omega is the same. As was the Manta that I made the puller for  ;)  :y
unlucky alf
  • worksop, notts
« Reply #7 on: 08 June 2010, 00:13:50 »
just leave the nut on a few threads then get a punch on the top of the shaft & hit down on it, i know it sounds dodgey but this is how vx told me to do it years ago in my monza days & has never damaged anything. :y
hotel21
  • The Kingdom of Fife
« Reply #8 on: 08 June 2010, 00:18:11 »
Done the same.
Sit on the drivers seat and put a fair wee bit of pull on the steering wheel at the 3/9 position whilst someone else clouts the centre nut with a chunky hammer.  Keeping the nut on by a few turns saves you getting a mouthfull of steering wheel and a dentist visit!   ;D
« Reply #9 on: 08 June 2010, 00:32:51 »
the potential flaw in hitting the end of the column is that it can damage the collapsible bit.
hotel21
« Reply #10 on: 08 June 2010, 00:39:24 »
As long as neither of you is Geoff Capes and using a long handled Monday hammer, should be fine....
But, good to point out.   :y
« Reply #11 on: 08 June 2010, 01:07:15 »
As long as neither of you is Geoff Capes and  ....
That's definitely me out then. More like Mr Muscle these days  :-[  :-[  :-[
Cliffo B
  • Leeds West Yorkshire
    • 03 3.2 Elite Estate
« Reply #12 on: 08 June 2010, 01:49:44 »
Get the proper VX puller 2 legs locate in the egg shaped holes in the boss, then screw centre bolt on to column end it's off in a jiff. made one years ago,but finally bought one. I do like proper tools.Seem to remember it cost less than £20.00.
Hannah Judes Dad
« Reply #13 on: 08 June 2010, 07:08:59 »
We're not related are we?  ;D
