Author Topic: none starter please help  (Read 980 times)
griff1
  • radccliffe manchester
« on: 08 June 2010, 20:41:19 »
hi chaps need help again have just changed the water pump and timing belt but forgot to note which timing mark on exhaust cam should be used on a 2000 2.0ltr ecotec engine can you lads point me in the right direction. had to change water pump after pulley fell off at tick over revs so no other damage as far as i can tell cheers griffo :'( :'(
same #same#
  • south yorks
  • dont blame me im dyslexic
Re: none starter please help
« Reply #1 on: 08 June 2010, 23:18:19 »
top cams line up with the nockes on the top case, pulley lines up with the spike top right of the pulley, timiming markings are left side line old right side new (meaning belt) there are two types one with the words on and one with the lines, all should be lined up on number one piston front, before running engine turn engine by hand to make sure that the timing marks stay the same if not redo, if the pully if of when doing timing markins are at the bottom of the pully shaft. allways check by hand before running engine. hope this helps :y
« Last Edit: 08 June 2010, 23:20:08 by Russ76 »
griff1
« Reply #2 on: 09 June 2010, 11:02:37 »
thanks but cam wheel on right side has 2 sets of marks one says intake other says exhaust i asume it would be the exhaust mark buy wanted to be sure before turning engine over
« Reply #3 on: 09 June 2010, 12:06:15 »
E=exhaust, I=inlet
So right hand pulley is exhaust.
My money is on bent valves though....idling or not.
same #same#
  • south yorks
« Reply #4 on: 09 June 2010, 13:08:05 »
if you hear a clicking sound hard to describe sounds out of place then there is somthing wrong, easy to see better with the top off, when turning engine over by hand.
