Author Topic: How much auto transmission fluid for a 3.2v6?  (Read 3181 times)
keithnic
  • Dunbar
« on: 06 June 2010, 22:42:58 »
I'd like to change the ATF on my nine year old 100,000 mile 3.2v6.  I saw on one thread that it takes 1.3 litres, but the Opie Oils website implies I need 4.5 litres.  Please can anyone clarify the quantity of trasmission fliud I need. TIA.
tidla
  • solihull
Re: How much auto transmission fluid for a 3.2v6?
« Reply #1 on: 06 June 2010, 22:45:50 »
4.5ltr ish
« Last Edit: 06 June 2010, 22:46:18 by tapper888 »
markspark
  • Bolton
« Reply #2 on: 06 June 2010, 22:46:44 »
dexron 3 4.4ltr thats what autodata say
keithnic
  • Dunbar
« Reply #3 on: 06 June 2010, 22:47:29 »
Brilliant, thanks very much Tapper888.
tidla
  • solihull
« Reply #4 on: 06 June 2010, 22:52:36 »
theres a method /guide for getting the correct level somewhere..
keithnic
  • Dunbar
« Reply #5 on: 06 June 2010, 23:34:10 »
Just purchased ATF and engine oil from Opie Oils.  Members get a further 15% discount at the moment so thats handy.
BTW in the maintenance guide it mentions about fitting a new washer.  Would I get this from a VX dealer?
« Reply #6 on: 06 June 2010, 23:41:42 »
Yes, you can get the washer from a dealer.Get a filter while your there.Not much point changing the ATF and leaving the old filter in there. ;)
keithnic
  • Dunbar
« Reply #7 on: 06 June 2010, 23:51:33 »
Cool, thanks for the tip.  Didn't know the autobox had a filter :-)
tidla
  • solihull
« Reply #8 on: 06 June 2010, 23:51:59 »
and a gasket if your taking the sump off..(more money)
« Reply #9 on: 07 June 2010, 07:06:30 »
two gaskits for front and rear sumps, or use an instant gaskit of the correct type. The filter (and magnet in the sump) can be cleaned, filter from dealers is 70 odd quid. And i distinctly remember it taking more than 5litres................. surely?
there is a guide in naintenance re the fill procedure, fill to level hole, start engine, re fill,  select all gears and check again, test drive check again, or something like.
far better done on a ramp imo.
« Reply #10 on: 07 June 2010, 08:52:31 »
BTW, you will need 6-7l of DIII to replace the ATF in the autobox - it holds about 9l, but its not (easily) possible to get it all out.
Worth buying 2 large cans of Fuch 4000 from Opie.
Cliffo B
  • Leeds West Yorkshire
    • 03 3.2 Elite Estate
« Reply #11 on: 07 June 2010, 09:06:44 »
Too late again, but this may help as I did the job 2 months back I got my bits from Jpat Inv details- Pt No 209 25 01 Gasket front pan GM4l30e BMW,VX, £4.39.  Pt No N209 25 02 Gasket rear pan GM 4L30E VX only £4.79.  Pt No N209 27 01 Filter, GM4L30E AR25,VX 44mm £15.76. The price's given are with 25% off, I think for Forum members. :y :y Contact details are Tel 08451304754   www.jpat.co.uk info@jpat.co.uk  Hope this helps
Cliffo B
« Reply #12 on: 07 June 2010, 09:37:04 »
Forgot to mention prices don't include vat  :'(
MickAP
  • South Derbyshire
« Reply #13 on: 07 June 2010, 11:04:10 »
Think I read somewhere that you could get away without buying the filter, it can be cleaned and reused.
Is this correct?
Mick ;)
keithnic
  • Dunbar
« Reply #14 on: 07 June 2010, 11:41:11 »
How do you clean the filter? Pls excuse my ignorance.
I'm not planning to take sump off, just to replace ATF as I guess its never been done.  Would like to get the gearbox software updated too and planning to ask Hotel21 nicely to do this for me once oil change done.
