Author Topic: oils...  (Read 1082 times)
Boditza
  • Craiova, Romania
oils...
« on: 10 June 2010, 21:22:50 »
I just bought the car, it has 200.000km and although gm says that the gearbox and diff oil is for life i really don't believe them so i want to change the diff oil, gearbox, brake fluid and power steeringoil. can anyone please tell me the gm codes for the oils i should put in because i want to use their oils.
Re: oils...
« Reply #1 on: 11 June 2010, 00:42:18 »
dont know the numbers, but you'll be paying over the odds for all except engine oil i'm fairly sure.
pas any dexron 2
atf any dexron 3  but fuchs titan 4000 is good enough
you need a hypoid hi sheer gear oil fot the dif, spec is in the dif guide, halfords do it.
Brake fluid any 4dot halfords again.
Cant help any more than that, but you may be interested in the trade club cards listed below which ever way you go. Def worth getting hold of both.
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: oils...
« Reply #2 on: 11 June 2010, 01:35:23 »
pas any dexron 2
Do Hellfrauds have a branch in Romania Chris? ;D
TuBy's new whipping boy.
Re: oils...
« Reply #3 on: 11 June 2010, 08:21:25 »
pas any dexron 2
Oh 'dangle berries'!  ;D   sorry Boditza  :-[
Boditza
  • Craiova, Romania
Re: oils...
« Reply #4 on: 11 June 2010, 09:43:01 »
np.. i want to do that because on my old astra i didn't change the gearbox oil when it was almost time to sell and that made a hell of a difference in changing gears :)
