Author Topic: Vacum tank  (Read 1110 times)
mrjimbo
  • Oxfordshire
Vacum tank
« on: 11 June 2010, 17:38:26 »
Does the front vacum tank, the one connected to the multi rams have a one way valve on the larger of the 2 nipples ?
Re: Vacum tank
« Reply #1 on: 11 June 2010, 18:31:53 »
Yes..
mrjimbo
  • Oxfordshire
Re: Vacum tank
« Reply #2 on: 11 June 2010, 18:39:53 »
So it does have a one way valve in there  >:(  been getting conflicting opinions regarding this  :-?
Now, mine has become stuck/blocked/jammed and there is absolutely no flow through it whatsoever. Can the valve be drilled out and a one way valve from a screen washer be fitted inline close to the vacum tank nipple or can the vacum tank be by-passed altogether as a temporary fix or am i goosed ?
Re: Vacum tank
« Reply #3 on: 11 June 2010, 18:47:16 »
I use a fish tank one way valve....but you do need flow through the tank.
Or just get a new one or good second hand one.
mrjimbo
  • Oxfordshire
Re: Vacum tank
« Reply #4 on: 11 June 2010, 18:52:32 »
I don't think i'll be able to get hold of one untill next week now so looks like i'll have to see if i can get the old valve out some how.
