Author Topic: Should I worry?  (Read 1551 times)
mr ICE man
  • dolgellau wales
  • if it aint broke try and fix it
Should I worry?
« on: 08 June 2010, 16:09:53 »
Was on the motorway today doing 70 and the oil level low sign came up on display??stopped immeadiatly and topped it up,warning gone but I only changed the oil and filter 2000 miles ago and was all at correct level.checked on Sunday and al was ok.water level tiny bit low so topped that up.no patches of oil anywhere on driveway or engine as I cleaned the engine and bay on Sunday and no smoke when driving!so the question is should I worry or not?just keep checking it?Thanks guys! :y
scream if you want to go faster!!!
Shrek
  • Fife , Scotland
Re: Should I worry?
« Reply #1 on: 08 June 2010, 16:19:39 »
I had this on mine just recently too . Level was at 3/4 and i was going round a long left turn when it flashed up Oil level .
I wouldnt worry too much unless it comes on again or unless the red oil light was on as well  .
It comes on i belive if its 3/4 on the dipstick and maybe going round a bend or corner made it think it was lower  :-/
« Last Edit: 08 June 2010, 16:23:35 by Shrek »
"My Naff Code Reader" and OBD2 readers available .
Re: Should I worry?
« Reply #2 on: 08 June 2010, 16:44:09 »
As Shrek ::) says. Oil light is known to illuminate when level is below max on dipstick :y
mr ICE man
  • dolgellau wales
Re: Should I worry?
« Reply #3 on: 08 June 2010, 16:58:11 »
Woo!relief!thanks guys!
bigtow
  • rochester kent
  • 2001 3.2 MV6 manual was 2.6 auto
    • x type 2,0d estate
Re: Should I worry?
« Reply #4 on: 08 June 2010, 17:55:54 »
Hmmm I had the check oil level warning come up today aswell I was going in a straight line towards a slip road . I had this on my mv6 just befor the oil cooler let go . So keep a eye on the coolent for oil . Fingers crossed its just a hyper active sensor
2001 MV6 3.2 manual been converted from 2.6 auto
Re: Should I worry?
« Reply #5 on: 08 June 2010, 18:04:21 »
It tends to come on when cruising, when the oil approaches halfway between min and max.
Try to keep it topped up to near (but not above) max.
bigdods
  • Brackley
Re: Should I worry?
« Reply #6 on: 08 June 2010, 21:35:33 »
Oil must be going somewhere though ? Check in the plug wells for a start. My 3.0 doesnt use a drop between services now, the only time it started slowly losing oil the cam covers gasket had gone.
yorkie25v6
  • SLady bitshorpe
Re: Should I worry?
« Reply #7 on: 12 June 2010, 02:54:24 »
hi guys,
my oil light flickers on and off when i have come to a stop after it's been on i decent run..
so i also ask should i worry.. :question
 plus what temp would you peeps say is normal?
it is my 1st omega and am loving it i am  just a bit concerned about the light flickering  :-/
 it does go off when driving and has never flickered whilst moving
« Last Edit: 12 June 2010, 02:56:09 by yorkie25v6 »
Re: Should I worry?
« Reply #8 on: 12 June 2010, 11:14:01 »
hi guys,
When you say temp I am asuming you mean water temp.  If this is the case the needle should be at half way point on the gauge.
