Author Topic: Water in passenger footwell  (Read 1307 times)
bert
« on: 11 June 2010, 13:19:10 »
Hi went to work this morning, notice about 2 inches of water in passenger footwell it was raining very heavy just got back from work had a look found water full up to pollen  filter poked around with screwdriver felt some sort of rubber bung in bottom, water slowy drained loads of rubbish  cannot see and cannot feel ,is there some sort of drain hole >:( thanks
Re: Water in passenger footwell
« Reply #1 on: 11 June 2010, 13:29:19 »
All explained here .. :)
http://www.omegaowners.com/forum/YaBB.pl?num=1167524083
Common problem, simple fix .. :)
bert
« Reply #2 on: 11 June 2010, 13:31:57 »
Thanks Entwood it did have me worried at work thought it might be something major cheers  :y
MickAP
  • South Derbyshire
« Reply #3 on: 11 June 2010, 20:24:18 »
I've had this problem.
Just make sure you dry those carpets off properly, they will start to pong a bit if not.....
Oh and check the rear footwell as well, it flows back into there sometimes :y
Mick ;)
eliteomegaman
  • Bolton, Lancashire
  • if it aint broke dont fix it....
« Reply #4 on: 12 June 2010, 12:01:06 »
O.M.G. that brings back memories  :o :o :o
Had exactly the same thing happen to me!!
Had a poke round with a long screwdriver till i eventually found the rubber bung at the bottom, wiggled the gromet & as the water poured out ended up with wet feet!!
But water settled again so this time i managed to push the gromet out (after cut & bruised hand!) and never had the problem again  :y
Mick is correct about the rear footwell cos mine was soaking wet as well as the front!! In a way your lucky its 'summer' cos u can leave all the windows slightly open to air the cabin. I had to pull up the carpets & using a spongue soak up all the water then put down 'Plenty' kitchen paper & change it every day till eventually it dried out! I also put down a plastic container filled with salt cos that helps draw in moisture  :y :y
Good luck & hope this helps  ;)
Andy
bert
« Reply #5 on: 12 June 2010, 12:45:04 »
Thanks for all the info did same thing used screwdriver pushed gromit out why do they put one there in first place, the hole must be rather smal,l cant believe that electrics run thru there if this happens  :y
