Author Topic: lpg vaporiser  (Read 1175 times)
andrew203
lpg vaporiser
« on: 11 June 2010, 20:23:44 »
Hi, began my lpg install, so far,
drilled and fitted manifold nozzles and hose,
mounted ecu and threaded the loom through,
soldered and mounted the switch,
soldered the ecu connections today.
Now im coming to fit the vaporiser and have a question, does the orientation  that i mount it matter? the way i intend to do it is with the gas inlet/solenoid at the bottom and the outlets facing upwards. is this ok or is there a rule?
cheers
andy
Re: lpg vaporiser
« Reply #1 on: 11 June 2010, 21:37:43 »
depends on the vaporiser, mine has gas feed on top / from the back.
This is mine:
andrew203
Re: lpg vaporiser
« Reply #2 on: 11 June 2010, 23:56:08 »
only brand on it is motogas (from telo), so is it cool if i mount this with the solenoid and inlet at the bottom?
cheers
andy
Re: lpg vaporiser
« Reply #3 on: 12 June 2010, 00:12:25 »
Andy, it needs to be mounted so that the water inlet and outlet are positioned to ensure proper flow, i.e. Inlet at the bottom, outlet at the top. Generally the splendid would be vertical but I'm on my phone so the picture is difficult to view. Also, it should ideally be mounted in a front - rear orientation otherwise you may get issues under hard acceleration/braking. You can use the pictures in the 4 pot guide to help.
andrew203
Re: lpg vaporiser
« Reply #4 on: 12 June 2010, 00:23:02 »
thanks a lot mate. when you are able to view the images well, could you tell me the way i should mount this vap please?
has anyone else had the need to relocate the cruise control motor. just incase i need to, where did you put it?
cheers
andy
Re: lpg vaporiser
« Reply #5 on: 12 June 2010, 16:52:45 »
Had another look... Mounted like the first picture shows, with the water inlet at the bottom and water outlet at the top is fine :y
But you can rotate the inlet if you need to... Just make sure you use lock and seal on it when you have it in the place you need it :y :y
« Last Edit: 12 June 2010, 16:54:13 by Lazydocker »
andrew203
Re: lpg vaporiser
« Reply #6 on: 12 June 2010, 17:56:08 »
thanks a lot for that pal!
andy
