Author Topic: airbag light  (Read 1676 times)
tommycon
  • oldham
airbag light
« on: 11 June 2010, 17:03:39 »
hiya,
 i replaced my front N/S door yesterday, drove the car this morning and the airbag warning light is on, i dont think this is related just asking to see if anybody else as had this happen, i know people dnt change doors that often.
 cheers
Re: airbag light
« Reply #1 on: 11 June 2010, 17:09:36 »
hiya,
 cheers
It is related because the impact sensor in the door has been unplugged, you need tech2 to turn the light off  :y
tommycon
  • oldham
Re: airbag light
« Reply #2 on: 11 June 2010, 17:14:17 »
that sounds about right , i didnt think  the impact sensors were in th door, i`ll be gutted if i`ve got to pay out just to have someone turn the light off
Re: airbag light
« Reply #3 on: 11 June 2010, 17:16:38 »
Sensor unit runs length of the door at the bottom, its a pressure sensitive one for side impacts.
OOF has tech2, nearest one to you would be MarksDTM in Nottingham, he can reset it, dealers will charge anything from £20-70
  • Online Online
Re: airbag light
« Reply #4 on: 11 June 2010, 20:56:33 »
If you can live with it for a few weeks, my 'Cheapo Tech II' should be able to turn it off for you. I'm busy all this week end, then in work till Sat then away for a fortnight.
Then I need to see someone in Swinton!   ::)  ::)  ::) .......
  • Online Online
Re: airbag light
« Reply #5 on: 11 June 2010, 20:59:35 »
... nearest one to you would be MarksDTM in Nottingham,  .......
Mmmm? 80 miles worth of fuel to Nottingham, it'd be almost as cheap to book it in at the dealers  ;)  ;)  ;)
Re: airbag light
« Reply #6 on: 11 June 2010, 21:35:02 »
True, but DTM knows how to use his tech2  ;D
tommycon
  • oldham
Re: airbag light
« Reply #7 on: 13 June 2010, 09:36:22 »
that would be great, i`ve got to replace the drivers door yet so is it ok if it tie up with you later??
does this mean that all my airbags won`t be working now????
 cheers Paul
  • Online Online
Re: airbag light
« Reply #8 on: 13 June 2010, 13:27:27 »
 cheers Paul .....
Speak to you in a couple of weeks then.  :y
and you're right, none of the airbags will work
