Author Topic: camber  (Read 1268 times)
tidla
  • solihull
camber
« on: 13 June 2010, 22:56:36 »
got a similar problem "growing" on my mig. slight wear on the inside of the tyre.
i have switched the tyres around from front to rear to extend the life and " see" what happens.
as aways i have similar experiences ( tracking only a little out, not worth adjusting) to find the inner of the tyres fubarded in a matter of months.(escort van)
new tyres fitted and insisted that the tracking be adjusted. sorted..
on the mig the wishbones are in a serviceable condition and the springs in one piece.
the only adjustment point i can see is on the strut to hub mount bolts.
there is this
but it only does degrees not minutes.
this on the other hand
although simple, build correctly using a bit of maths could.
opinions?
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
Re: camber
« Reply #1 on: 13 June 2010, 23:01:47 »
I've had two migs put on the computer now and had cam bolts fitted and the tyre last more than 12k with 0 camber.
Re: camber
« Reply #2 on: 13 June 2010, 23:10:33 »
. build correctly using a bit of maths could.
opinions?
Mmmm :-/ Is that something to do with old horses cantering over hills .......   ;D ;D ;D
« Last Edit: 13 June 2010, 23:10:50 by Andy_B »
Re: camber
« Reply #3 on: 13 June 2010, 23:22:27 »
I wouldn't bother with the first solution. The spirit level with bolts through it can achieve surprisingly accurate results, though, IME.
Problem is, it will put your toe adjustment out anyway, and that's less easy to get right on a DIY basis.
tidla
  • solihull
Re: camber
« Reply #4 on: 13 June 2010, 23:22:34 »
is the "official setting 1 10?
Re: camber
« Reply #5 on: 13 June 2010, 23:23:12 »
opinions?
Showing your age now Andy, and its around hills not over them .. :) ... SOHCAHTOA .. or as the venerable Mr Tingley taught me well over 40 years ago ..
Some Old Hags
Creep Around Highworth
Trampling On Ants
and it still worked when I did my OU degree !!!!!
 :D :D :D :D :D :D
tidla
  • solihull
Re: camber
« Reply #6 on: 13 June 2010, 23:24:34 »
fair enough, camber set up first, then £20 for the toe/tracking  set up.
tidla
  • solihull
Re: camber
« Reply #7 on: 13 June 2010, 23:31:14 »
opinions?
Some Old Hags
Trampling On Ants
 :D :D :D :D :D :D
will print that off for future reference :y
Re: camber
« Reply #8 on: 14 June 2010, 08:13:08 »
Silly Old Harry
Caught A Herring
Trawling Off Afghanistan (and hence why he was silly!)
