Author Topic: EML light on, and fault code 0130...  (Read 794 times)
DanielF
« on: 13 June 2010, 23:33:09 »
Hi guys!
I have an Omega 2.0 16V 97mod. and the EML light comes on about 1 minute after I start the engine. I did the paperclip test and got the code 0130, indicating that there is a problem with the O2 sensor. Should I change it right away or is it something  else I should check to rule out any other problems that can give this fault?
Thanks!
same #same#
  • south yorks
  • dont blame me im dyslexic
Re: EML light on, and fault code 0130...
« Reply #1 on: 14 June 2010, 08:49:34 »
is there any other faults, dose it run ok or is it in limp mode?
DanielF
« Reply #2 on: 14 June 2010, 09:24:31 »
It seems to be running just fine.. At least I did not notice anything unusual...
Pleas help :o
