Author Topic: TYRE WEAR - SQUEELING  (Read 3628 times)
idwal
  • telscombe cliffs near brighton
    • Mv6 estate (2000) Lpg
« on: 13 June 2010, 17:00:22 »
I had the tracking done on my MV6 as front
tyres worn on inside so change front pair and had
tracking done at same time.
wheels are facelift 245/45/17
Every since the front tyres squeel - I had kwik fit check
tracking again and said maybe a degree out on front
but nothing to worry abount
Checked the tyres after going into town and all I can
say is the both tyres ok on outside and seem to be
wearing on inside - I say about 15/20 degrees from outside edge to inside - hense the squeeling
Is this just tracking or could it be something else?
thanks
ken
manny
  • bromorough.Wirral.
Re: TYRE WEAR - SQUEELING
« Reply #1 on: 13 June 2010, 17:01:49 »
Wishbones are goosed.
2001 OMEGA MV6
idwal
« Reply #2 on: 13 June 2010, 17:03:23 »
is that an exspensive job?
thanks
ken
manny
« Reply #3 on: 13 June 2010, 17:09:01 »
They are about £60 a side from all german parts. My MV6 had the exact problem with it wearing inside edge of tyre. As you brake wheels want to push back which makes tyre run on inside edge,
2001 OMEGA MV6
manny
« Reply #4 on: 13 June 2010, 17:19:39 »
Just to add, dont buy cheap ones as they dont last.
2001 OMEGA MV6
idwal
« Reply #5 on: 13 June 2010, 17:21:16 »
Have seen some on ebay (300350512040)
is this a fair price or where should I go for
decent parts
thanks
ken
manny
« Reply #6 on: 13 June 2010, 19:16:28 »
Vauxhall car parts do them for £25 a side. Dont know what the quality is like. Maybe someone will can give an opinion on them?
2001 OMEGA MV6
« Reply #7 on: 13 June 2010, 19:24:21 »
I would not be condeming the wishbones until you have checked them but, tracking will not have caused the tyre wear, camber will have.....and as you have not had this corrected then they will wear again
manny
« Reply #8 on: 13 June 2010, 19:33:58 »
decent parts
thanks
ken
The wishbones you have seen come with drop links. Now i dont know what the quality is like but if you do buy new wishbones get the drop links also as they are cheap enough. The reason i say this is when i done mine the drop links were a pig to get of as threads were bad. That is if it does turn out to be the wishbones? :y
« Last Edit: 13 June 2010, 19:34:42 by manny »
2001 OMEGA MV6
idwal
« Reply #9 on: 13 June 2010, 19:37:36 »
I have very little mechanical knowledge but it is funny
that this happened only after I had tracking done.
could it be possible that they did not tighten everything up
after tracking done - as fault only occured after tracking was done.
ken
manny
« Reply #10 on: 13 June 2010, 19:48:24 »
ken
The only thing i can suggest is to get a second opinion on the tracking. Or take it back and get it checked again by the garage who done it.
2001 OMEGA MV6
« Reply #11 on: 13 June 2010, 19:49:24 »
CAMBER!
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
« Reply #12 on: 13 June 2010, 19:51:01 »
As Mark has said could be the camber that's out, but could also be the wishbones.  Any MOT station should be able to check the wishbones for you.
The equipment that Kwik-Fit and the like use for tracking will not give an accurate setting.  Even the gear that VX dealers use is useless - I could tell you a long story but it makes me too angry!
Go somewhere that does full 4 wheel alignment using Hunter gear, for example.  Don't be fooled by claims of "4 wheel laser alignment"... go to a specialist, it'll cost you a lot less than another pair of tyres!
My local place charges £35 + VAT to check front camber, rear camber, front tracking, rear tracking, thrust-line and probably more that I can't remember.  You get a printout before and after adjustment and they charge £25 per hour for making the necessary adjustments.
Obviously, replace any faulty parts BEFORE getting the alignment done.
« Last Edit: 13 June 2010, 19:55:50 by sjc »
manny
« Reply #13 on: 13 June 2010, 19:54:59 »
CAMBER!
No need to shout i hear what your saying. Idwal said he only got the problem after he had the tracking done that it why i told him to take it back.
2001 OMEGA MV6
sjc
  • Alloa, Scotland
« Reply #14 on: 13 June 2010, 19:57:32 »
CAMBER!
But he took for tracking because the tyres were scrubbed.  Camber being out causes scrubbing.
