Author Topic: Back Plate / Handbrake shoes,  (Read 1943 times)
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
« on: 14 June 2010, 20:47:02 »
I have a 2,0 N Reg ( 1996 ) Omega,
I have two questions
1, How the do I get the back plate off ? Ie the hub, what tools do I need, and how does it go back in ???
2, Where can I get a new one and what is the price for it.
Its the Rear pass, side.
Any tipps welcome.
Thanks.
He who brakes Looses
To old to die young
same #same#
  • south yorks
  • dont blame me im dyslexic
Re: Back Plate / Handbrake shoes,
« Reply #1 on: 14 June 2010, 21:00:16 »
if you take the drum off there is 2 bolts holding the back plate on, mine used to be trox type on mine but when I changed them with plate put 2 8mm bolts in  as right size not to interfere with the hand brake, original ones are hard to get out when rusted, drill'd the tops off then drilld the bolt out and re-threaded the hole. £10, vx
« Last Edit: 14 June 2010, 21:26:49 by Russ76 »
« Reply #2 on: 14 June 2010, 21:08:04 »
IIRC To change the backplates involves pressing the wheel bearings out with a hydraulic press.  :'(
« Last Edit: 14 June 2010, 21:09:11 by RobG »
  • Auckland
    • Mazda MPV
« Reply #3 on: 14 June 2010, 21:17:08 »
I think Matchless wrote a guide to changing the rear hub bearings but I can't find it at the moment  :-/
To get the brake back plate off I believe you do need to pull the drive flange/stub axle out of the wheel bearing but I think the bearing can stay in the trailing arm. (getting the bearings out of the trailing arms can be a mare of a job if rusted in)
