Author Topic: Auto Gearbox Issues  (Read 1155 times)
Reidy79
Auto Gearbox Issues
« on: 17 June 2010, 15:37:45 »
Hi Guys,
New to the forum so please bear with me, I think I have all the salient facts but if not I can get them
My partners dad has an '03, 2.2 Petrol, Omega Estate, Automatic
It has developed an issue which is as follows
When put in drive the indicator lights near the gear lever all light up (his words) and it goes into limp home mode
If he reverts to using it as a manual essentially he can drive the car
He has spoken to a garage who have said it is his ECU and it needs replacing
They have said it would be £700 all in for a replacment ECU, fitted and any investigatory work, he did say they didn't seem entirely confident this was the issue, but seemed to think it was a starting point
He loves the car but is obviously reluctant to throw all this money at it on a whim
I have looked at the FAQ and Common Issues section and notice that there does seem to be a link between the ECU and the gearbox, does this sound like the same issue?
As a side note, can anyone recommend a garage in the South East London area (Greenwich, Lewisham, Eltham) who have more knowledge about these things or aren't potential cowboys?
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: Auto Gearbox Issues
« Reply #1 on: 17 June 2010, 15:41:55 »
Sounds like the gearbox selector switch playing up to me.
Oh and a garage clutching at straws because they've no idea what's wrong.
Often taking the switch off the gearbox and giving it a good clean out can cure it but otherwise replacing with a known good one from one of the breakers on here will cure the problem.
TuBy's new whipping boy.
Reidy79
« Reply #2 on: 17 June 2010, 15:59:48 »
That certainly sounds feasible and certainly couldn't hurt, cheers
Is that an easy job?
Edited to Add: I have found the guide, with pictures  :o I'm gonna have to show her dad this place, I think he would like it  :y
« Last Edit: 17 June 2010, 16:04:15 by Reidy79 »
« Reply #3 on: 17 June 2010, 17:09:41 »
Best place there is for anything you want to know about Miggys :y :y :y
Steveplumb
  • Radstock, Near Bath
« Reply #4 on: 17 June 2010, 17:14:50 »
I have the same problem , except the lights do not come on. The selector switch is being cleaned up tomorrow,  I will post in a few days whether or not it has cured the problem. Also checking fluid level  at the same time .  This seems to be a fairly ' common' issue, yet it seems several things can create the same symptoms.  But replacing the ECU first is just crazyyyy .
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #5 on: 17 June 2010, 17:22:54 »
You will be suprised by cleaning the selector switch will more than likely solve your problem as The Captain has said :y
Page created in 0.021 seconds with 16 queries.
