Author Topic: misfire  (Read 1892 times)
paintshoptec
  • cheadle, stoke - on -trent
    • 2002 cd v6 saloon
misfire
« on: 10 June 2010, 23:07:38 »
hi all
got a random misfire on 1 and 3 changed the spark plugs and still got a misfire does this mean its the coil pack or can it be something else
thanks
same #same#
  • south yorks
  • dont blame me im dyslexic
Re: misfire
« Reply #1 on: 11 June 2010, 12:03:01 »
have you changed the leads???
Re: misfire
« Reply #2 on: 11 June 2010, 12:06:49 »
2.6 mate  ;)  ;)  ;)
same #same#
  • south yorks
Re: misfire
« Reply #3 on: 11 June 2010, 12:42:24 »
sorry could not see that out side sun is blinding
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: misfire
« Reply #4 on: 11 June 2010, 16:58:35 »
pm daz ( loo-knee )
he is in stoke  :y
Re: misfire
« Reply #5 on: 11 June 2010, 17:14:46 »
any oil / water in the wells?
paintshoptec
    • 2002 cd v6 saloon
Re: misfire
« Reply #6 on: 11 June 2010, 21:38:33 »
took it off today and found  corrosion on 1 and 3, plugs are ok but change them just in case
new coil ordered from vauxhall parts warehouse
all the plug wells are dry
paintshoptec
    • 2002 cd v6 saloon
Re: misfire
« Reply #7 on: 15 June 2010, 18:52:44 »
new coil pack and plugs fitted. took the car for a run and checked codes when i got home and all was clear,got to work this morning and did the pedal test
faults are logged miss fire on 1 and 3
any ideas anyone
thanks
paintshoptec
    • 2002 cd v6 saloon
Re: misfire
« Reply #8 on: 15 June 2010, 23:32:34 »
cleared fault codes restarted the car with in 10mins running on tick over the e/m light came on checked codes again now got a misfire on 1 3 5
HELP
paintshoptec
    • 2002 cd v6 saloon
Re: misfire
« Reply #9 on: 16 June 2010, 18:22:30 »
cleared codes again left it to run on tick over codes are back again on 1and 3
paintshoptec
    • 2002 cd v6 saloon
Re: misfire
« Reply #10 on: 16 June 2010, 18:30:32 »
did have the cambelt changed last tuesday if the timming is out would that cause the fault codes 0300 ,0301,0303
Re: misfire
« Reply #11 on: 16 June 2010, 18:36:03 »
unplug the MAF and see what happens...
paintshoptec
    • 2002 cd v6 saloon
Re: misfire
« Reply #12 on: 16 June 2010, 19:20:40 »
no change
paintshoptec
    • 2002 cd v6 saloon
Re: misfire
« Reply #13 on: 17 June 2010, 19:28:01 »
what should happen when you unplug the maf
