Author Topic: Steering feels tight  (Read 803 times)
« on: 17 June 2010, 23:28:46 »
3.0 Elite
Was fine last time out and had found all tyre pressure were all over the place.
26/40 front 24/35 rear, the 24 psi was found to be because of a screw, and other high settings from inacurate garage equipment.
Any ways, just been out and the steering feels heavy and pulls to the left, coming round a roundabout I let go of the whell and it took me off to the left as I turned of to my turning perfectly  :-[ looked at the tyres as I got home as it felt like the passenger front was low on air but looked fime, will check the PSI on both romorrow.
What might I be looking at regards it being tight and pulling to the left if the pressures are ok.
TIA.  :y
hotel21
  • The Kingdom of Fife
Re: Steering feels tight
« Reply #1 on: 18 June 2010, 00:06:02 »
Always worth checking the fuses as its electrical and hydraulic assistance.  Fuse 14, from memory?  Also covers the rear cig lighter and other similar.  Usually a 5p piece or similar down the guts of it causing a short.....
« Reply #2 on: 18 June 2010, 00:43:26 »
Down where, where should I be looking.
hotel21
« Reply #3 on: 18 June 2010, 00:49:47 »
in the cig lighter housing, where you plug the cig lighter or male socket into??
