Author Topic: tractor not starting!!!!  (Read 1075 times)
jayten10
« on: 17 June 2010, 22:23:59 »
hi,
l have just taken a 1998 2.5 td elite, gave it service inc glow plugs, over the last few days have noticed when warm it will not start takes a few attempts then fine, today it done this so l decided to leave it a while, upon attemping to start it it just wouldnt in the end draining the battery,was fine in the morning took it for a 45 minute run any ideas? have had one of these before where it only gave problems fear l have made a bad investment >:(
charlie
  • sunderland
Re: tractor not starting!!!!
« Reply #1 on: 17 June 2010, 22:32:45 »
On the hot starting does the battery have enough power to get the correct crank speed needed,(they are harder to start when hot than cold with a  battery not 100%)
markspark
  • Bolton
« Reply #2 on: 17 June 2010, 22:33:46 »
cant help with the fix for this but im sure its been a topic on here in the past there is i think a fix for the hot start problem on egay
jayten10
« Reply #3 on: 17 June 2010, 22:41:23 »
the battery was ok til earlier when it wouldnt even turn over,so l left it for 3 hours and then it would crank but the battery was also dying out!!!
charlie
  • sunderland
« Reply #4 on: 17 June 2010, 22:52:37 »
As mark says there a kit on the bay that fools the ecu into thinking its cold for about 30 seconds :y
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #5 on: 18 June 2010, 00:52:39 »
Try this by clicking:   http://cgi.ebay.co.uk/Hot-Starting-Fix-Range-Rover-BMW-Diesel-P38-DT-DSE-/390089969957?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5ad32c9125#ht_2143wt_816
