Author Topic: Miss Fire... 2.5 V6  (Read 1681 times)
Steve 1564
  • North Somerset
  • IRRITANT
Miss Fire... 2.5 V6
« on: 20 June 2010, 13:04:45 »
Hi
5 miles from home after my marathon trip to scotland i developed a missfire...
It was a sudden event - up to that was running fine
No eml light (should i check for codes anyway ?
Had a look this morning and theres no spark on 2 (drivers side front) not sure about the other bank but nothing on 2...
Its a constant lack of spark & not failing under load or the such like...
I probably allready know the answer to this - but is it the dis pack ?... i guess what im asking is has anyone had a single cyl fail on one - leads should be ok (fairly new & lucas ones) but i'll get a spare to try & theres no sign of tracking anywhere (parked in a dark spot last night )
Cheers
Steve
"Have you had the back off it yet ?"
Re: Miss Fire... 2.5 V6
« Reply #1 on: 20 June 2010, 13:08:04 »
If its the dis pack you will have no spark on two cylinders. If its only no 2 not sparking its going to be the plug or lead ;)
manny
  • bromorough.Wirral.
« Reply #2 on: 20 June 2010, 13:09:23 »
Check lead and plug first.
2001 OMEGA MV6
Steve 1564
  • North Somerset
  • IRRITANT
« Reply #3 on: 20 June 2010, 13:11:40 »
Cheers pete - what i figured - I'll stick a finger in the leads on the other bank  :o  it is possible that it has a cyl down on the passenger side but the leads are a pain to pull...
Any idea how there configured? as it fires on the other 2 pots on the drivers side bank
Thanks Again
Steve
Steve 1564
  • North Somerset
  • IRRITANT
« Reply #4 on: 20 June 2010, 15:46:22 »
Oooo that bites ! :o
OK looks like no spark on 2 & 6... (although 6 did pop a bit when i took the lead off...)
Dis pack it is then i guess ::)
« Last Edit: 20 June 2010, 15:47:18 by Steve_1564 »
Steve 1564
  • North Somerset
  • IRRITANT
« Reply #5 on: 20 June 2010, 16:07:29 »
Re: Which is #1 cylinder
        5      6
        3      4
        1      2
       Radiator
D'oh....
Ok not fireing on 1 & 5 (bit like me!)
