Author Topic: omega estate prop shaft  (Read 1614 times)
spud1990
« on: 18 June 2010, 22:30:44 »
i need a new prop shaft 4 my estate where can i get 1 from?
Re: omega estate prop shaft
« Reply #1 on: 18 June 2010, 22:56:00 »
eBay? Manual or Auto? Make sure it comes from same transmission as ratios are different
« Reply #2 on: 18 June 2010, 23:05:31 »
 :-? He's after a prop shaft Tunnie, not a gearbox or diff  ;)  ;)  ;)
tidla
  • solihull
« Reply #3 on: 18 June 2010, 23:05:37 »
propshaft??
turning too slow..
« Last Edit: 18 June 2010, 23:06:11 by tapper888 »
same #same#
  • south yorks
  • dont blame me im dyslexic
« Reply #4 on: 19 June 2010, 01:39:52 »
depends were you live, and if you wont new or second hand, seen some new one for £260, second hand  between £60 - £120. full parts. new comes with rubbers etc, second hand comes as it cam off old car.
« Reply #5 on: 20 June 2010, 18:28:22 »
Didn't know you could get prop shafts with different ratios  :-? :) ;D ;D ;D ;D ;)
spud1990
« Reply #6 on: 20 June 2010, 22:31:23 »
its manual so they all will fit? i've completely snapped it n it twisted both ends like a piece of liquorice!!!!!!!!!!!!!!!!!!!! :-? :-? :-? ;) ;) ;) ;) ;)
i live in abergavenny south wales.
same #same#
  • south yorks
« Reply #7 on: 20 June 2010, 22:36:57 »
try scrapy.should be one near you, did the dif lockup on you???
