Author Topic: 3.2 v6 heads  (Read 1650 times)
v6 steve
3.2 v6 heads
« on: 19 June 2010, 13:43:00 »
hi there not been on for some time, i have a calibra with a omega 3.2L engine, can some one tell me are the heads the same as a 2.5 or are they diffrent ? it looks like my cam pully has sliped and bent some valves i have 4 2.5 heads kicking about so can i use the valves out of them or will it need to be 3.2 ones?
thanks for any help you can give
charlie
  • sunderland
Re: 3.2 v6 heads
« Reply #1 on: 19 June 2010, 14:13:32 »
dont quote me on this but the 2.6,3.2 have an extra hole for coil pack.there is some thing in faq or matanice guild with the difference in a 2.5 head and a 2.6 head hth AS for the internals of the heads i dont know if they are interchangable,i m sure some with the info will be along shortly. :y
« Last Edit: 19 June 2010, 14:25:43 by charlie »
Re: 3.2 v6 heads
« Reply #2 on: 19 June 2010, 16:24:31 »
Afraid they're different IIRCC... May be able to get away with 3.0 heads, although the holes for the coil packs wont be there :-/
Re: 3.2 v6 heads
« Reply #3 on: 19 June 2010, 18:16:34 »
no idea re heads but the 3.2 cam covers can be fitted for the coil pacs, fairly sure.
needs a reply from the master to be sure though.
v6 steve
Re: 3.2 v6 heads
« Reply #4 on: 20 June 2010, 00:32:28 »
iv pulled the valves out a 2.5 head i had kicking about and they fit in the 3.2 head, EPC is saying they have diffrent part numbers tho dose anyone know if i can use them?
Re: 3.2 v6 heads
« Reply #5 on: 20 June 2010, 01:02:28 »
I think 3.0 / 3.2 exhaust valves are sodium filled... I think otherwise, they should fit?
  • Auckland
    • Mazda MPV
Re: 3.2 v6 heads
« Reply #6 on: 20 June 2010, 15:59:31 »
I think the bigger engines should have a larger combustion chamber volume to keep the same compression ratio :-/
v6 steve
Re: 3.2 v6 heads
« Reply #7 on: 20 June 2010, 22:13:49 »
yee the heads are diffrent but are the valves the same iv tryed them in the 3.2 head and they seem to fit and seat ok so do i use them or buy new ones?
2woody
  • Northumberland
Re: 3.2 v6 heads
« Reply #8 on: 20 June 2010, 22:28:55 »
3.0 & 3.2 have sodium-filled exhaust valves, which will last longer. (they conduct heat away quicker and are therefore less likely to burn out)
2.5 do not have sodium-cooled valves.
you'll probably be ok to use the 2.5 ones, but use all 12. In any case, I'd get them professionally ground.
  • Auckland
    • Mazda MPV
Re: 3.2 v6 heads
« Reply #9 on: 20 June 2010, 22:33:16 »
Oops, sorry, was still thinking about head differences.
My assumption is that sodium cooled exhaust valves would be most important for autobahn trips or towing caravans.  :-/
v6 steve
Re: 3.2 v6 heads
« Reply #10 on: 21 June 2010, 23:10:32 »
its was only the inlet valves that got bent on one bank so im thinking the 2.5 ones should do
thanks for your help guys
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: 3.2 v6 heads
« Reply #11 on: 21 June 2010, 23:18:49 »
Depends Paul, if the 3.0 engine is a newer one it will have the two per side tapped holes for the coil packs :y
