Author Topic: Fitting a towbar  (Read 2786 times)
dizaster
  • Ipswich
Fitting a towbar
« on: 20 June 2010, 17:10:12 »
Hi alls,
I have been given a towbar from my cousins Omega, to fit on mine.
But  I cant for the life of me work out how it fits  :-)
Any ideas / suggestions ??
Photos below of the parts Ive been given
and from another angle
Cheers
charlie
  • sunderland
Re: Fitting a towbar
« Reply #1 on: 20 June 2010, 18:16:36 »
GO to the bay (omega towbar new ones,places like headly towbars in durham and download the fitting instructions,make sure the tow is from like for like ie saloon to a saloon estate to estate :y
Dodger
  • Here in the sunny south!
  • I taught I saw a puddytat!!
« Reply #2 on: 20 June 2010, 18:43:41 »
Try this link, should be the complete fitting instruction, as a PDF file, you can print it off, and compare what you have with the parts list.
Hope this helps, :y
Dodger. :)
http://www.towsure.com/home/pdf/844E.pdf
I always knew I'd inherit an estate, but I never thought this would be it!
same #same#
  • south yorks
  • dont blame me im dyslexic
« Reply #3 on: 20 June 2010, 23:49:26 »
Hi alls,
Cheers
were is the square bar as cannot see it?
« Reply #4 on: 21 June 2010, 00:07:43 »
Can't tell anything from those pics, but guessing I'd say it should have a plate on the boot floor to replace all that angle iron. :-/
same #same#
  • south yorks
« Reply #5 on: 21 June 2010, 00:15:09 »
sure it should have a long square bar, with two plates on the ends to fit under the boot, if i fitted it as it looks it would just rip of pulling the caravan etc, that looks a lot like a ford tow bar, what make is it should have a vin plate or stamp on it.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #6 on: 21 June 2010, 10:04:51 »
There are a few different types of towbar, but from what I can see from the picture which could do with being a bit bigger for me to see properly  ;D it looks like there is a big plate that should go inside the boot on the floor is missing.
The big part you have with the towball on, it has 4 hole drilled into it... you will need to open your boot, pull up the carpet. You will see 4 nipples in the floor and three under the plastic rear panel which you will need to remove. They all need drilling to the size of the bolts you have (10mm iirc)
I usually fit the rear bolts first (under the rear plastic panel) to make sure the towbar body is right back in the right place before drilling 10mm holes through the floor as they sometimes dont line up and you end up with elongigated holes (hope this makes sense)
There are 2 holes further up the boot nearer to the back seats which will got through the chassis, they also need drilling.
Whilst you have the Big Plate in place draw around it and remove the sound proofing from the floor :y
I would remove the towbar body getting all the swarf ( the twisty bits of steel after drilling) off, put the big plate (that it looks like your missing) in place then bolt everything up :y
Hope that helps, I am writing this from memory so bare with me :)
« Last Edit: 21 June 2010, 10:05:36 by Loo-knee »
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #7 on: 21 June 2010, 10:11:15 »
This is a good point  :y but it does look like a saloon towbar from what I can see, as the estates I have seen so I could be wrong, have a box section with a plate each end that bolts width ways to the brackets that are bolted through the floor each side of the sparewheel well :y
« Reply #8 on: 21 June 2010, 10:36:53 »
plate in the boot floor is the design i have, Rustym is talking ebout the other design, with square bar under the fuel tank which does not seem relevant here.
« Reply #9 on: 21 June 2010, 10:41:57 »
Don't know if its the same bar or not but try these.
Between the tank and bumper
Between the diff and tank
Inside the boot
« Reply #10 on: 21 June 2010, 14:29:48 »
I agree that looks incomplete. There must be something to spread the loads forward to the crossmember behind the diff. Either a plate that fits internally on the boot floor or a square section tube that runs forward under the fuel tank. :-/
You should also have long bolts to go through the crossmember and, importantly, spacers to fit inside it so it is not crushed as you torque the bolts up.
same #same#
  • south yorks
« Reply #11 on: 21 June 2010, 15:14:31 »
plate in the boot floor is the design i have, Rustymis talking ebout the other design, with square bar under the fuel tank which does not seem relevant here.
huh???
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #12 on: 21 June 2010, 20:26:11 »
Elite Pete looks a little rusty under there need some Waxoyl.
« Reply #13 on: 22 June 2010, 08:55:41 »
The poor old girl has been standing for over 9 months but she's not far off being finished now ;)
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #14 on: 22 June 2010, 09:49:48 »
My old girl needs something but I dont think that waxoyl is the answer
