Author Topic: control indicator light for exhaust  (Read 2511 times)
shell
  • Glasgow
« on: 23 June 2010, 22:50:00 »
The yellow light directly above the handbrake light on the dashboard has recently started to remain on for 3 or 4 seconds longer than usual after the car is started.(It is shown on p 150 of the user manual as control indicator for exhaust)
Can I ignore this?
TIA   shell
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: control indicator light for exhaust
« Reply #1 on: 23 June 2010, 23:08:06 »
If any light comes on mate it comes on for a reason. I would not ignore it.. anyone up there near you with a Tech2? Hotel21 is in the Highlands :y
shell
  • Glasgow
« Reply #2 on: 23 June 2010, 23:21:00 »
thanks Daz! we are in glasgow but can travel easily,and have a reasonably trusted local garage.Do you think this warrants a swift journey to local garage?
shell.
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #3 on: 23 June 2010, 23:22:32 »
Have you done the Paperclip Test Shell?
« Reply #4 on: 23 June 2010, 23:23:28 »
Try a paperclip test and post up the results .. :)
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #5 on: 23 June 2010, 23:24:24 »
You beat me I just went off to find the link ;D
shell
  • Glasgow
« Reply #6 on: 23 June 2010, 23:33:48 »
Thankyou all.. pedal trick first thing tomorrow.I know i should have done this first so thanks for your patience!
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #7 on: 23 June 2010, 23:35:22 »
Paperclip, rather than pedal trick as yours isn't a drive by wire engine. :y
TuBy's new whipping boy.
shell
  • Glasgow
« Reply #8 on: 24 June 2010, 11:46:24 »
Did the paperclip test this morning and this showed up
:73   Mass Air Flow Sensor Voltage Low .
« Reply #9 on: 24 June 2010, 13:01:20 »
woo, a rare maf code on a 2.5
as i understand it, maf reporting lower than feasable air volume/intake at a given rpm. Possible causes, MAF has been unplugged with ignition on. Dirty contaminated maf element (its buggered) or, faulty wiring to maf connector or plug.
Basickly if its not been unplugged recently and the wiring is ok, swap the maf for a known good one, clear the codes and see if the problem clears.
Suggest doing this sooner rather than later before maf fails properly.
« Reply #10 on: 24 June 2010, 13:04:29 »
ps, if it has an oiled panel or cone filter, remove and throw it directly in the bin then fit an original paper filter.
shell
  • Glasgow
« Reply #11 on: 24 June 2010, 13:24:31 »
No work has been done so i guess its unlikely to have been unplugged.
The only way to replace it for a known  good one will be to send it to garage and get it replaced.Any idea how much it might be for this part?
Thanks for your help!
davethediver
  • Blackburn, Lancs.
« Reply #12 on: 24 June 2010, 13:52:26 »
Easy enough to replace yourself, prices vary wildly but would suggest fitting an orginla bosch or siemens part and not some cheap ebay snide :y About 70 english off top of me head :-?
P.A. Caron de Beaumarchais
shell
  • Glasgow
« Reply #13 on: 24 June 2010, 14:30:36 »
70 quid doesn't sound too bad.I just had a good read at the FAQ on MAF sensor.I suppose that to replace it and air filter is my first course of action, so ill look into that this afternoon.
Many thanks for your help all!
shell xx
« Reply #14 on: 24 June 2010, 17:34:18 »
The other way is to swap with a member here to prove the fault will be rectified first.......if possible.
 given non drive by wire maf's rarely fail I'd consider one from a breaker on here also.
