Author Topic: Help  (Read 1628 times)
DaviesEB
  • Monrovia Liberia
Help
« on: 25 June 2010, 10:28:33 »
I lost my car key and just got a new one with chip and ecu. The Ignition barrel was also changed. But the mech tell me on switching on the igniotion there are no lights on the dashboard and car does not start.
Any help please. :-[ :-[
Bright
Used Opel Kadett 1.6 and refurbishing Opel Rekord 2.0
Re: Help
« Reply #1 on: 25 June 2010, 10:48:08 »
Any help please. :-[ :-[Bright
Engine ECU  :question Immobiliser module also needs changing. Ign connector fully home :question
« Last Edit: 25 June 2010, 10:50:04 by RobG »
DaviesEB
  • Monrovia Liberia
Re: Help
« Reply #2 on: 25 June 2010, 10:55:58 »
Hi there are you saying i need to change the engine ECU????? I got the car key and the module that goes around the neck of the steering from a memeber of the forum. Which is the Engine ECU????
Then it is a wasted effort.
I had a single key the chip in the key got lost. I then bought a new chip to insert in the key with a module that goes around the neck of the steer.
Well; as it is now can any one assist as to what way forward.  :-[ :-[ :-[
Re: Help
« Reply #3 on: 25 June 2010, 11:02:41 »
Transponder and immobiliser need to be paired to the engine ECU. Been easier to have left everything alone, bought a new key blade, had it cut and paired with TechII
Engine ECU is in triangular relay box by battery
« Last Edit: 25 June 2010, 11:03:32 by RobG »
Re: Help
« Reply #4 on: 25 June 2010, 11:08:10 »
You need the chip from the key, the pick up from around the barrel and the ECU which fits in the triangular box next to the battery. They should all come from the same car ;)
« Last Edit: 25 June 2010, 11:08:44 by Elite_Pete »
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Help
« Reply #5 on: 25 June 2010, 11:10:22 »
Can't remember 100%what you had from me Bright Key & Transponder Chip rings a bell in which case you will need to have the Chip Flashed with a Tech 2 mate.
Like said above if you want to change the lot the Engine ECU would need to be with it all :)
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: Help
« Reply #6 on: 25 June 2010, 11:20:11 »
All very confusing Could someone give an explaination of how the immobiliser system works
Re: Help
« Reply #7 on: 25 June 2010, 11:24:07 »
simples .. chip in key is recognised as "correct" by transponder ring around the barrel. Transponder ring sends correct signal to ECU to allow engine to start.
So to work key must talk to transponder, transponder must talk to ECU.
In order to "talk" they MUST be "paired" by tech2 ..  in simplicity "pairing" makes them speak the same language.
So all three parts   chip/transponder/ECU MUST be setup correctly to function. If any one part does not work/is not present  the ECU prevents the engine starting ... which is why its called an "immobilisor" .. :)
HTH  :)
DaviesEB
  • Monrovia Liberia
Re: Help
« Reply #8 on: 25 June 2010, 14:26:42 »
Where is the ECU located in the engine?????? I will ask around if anyone here has a mTech 2
Re: Help
« Reply #9 on: 25 June 2010, 15:25:29 »
Answered in my 2nd reply
