Author Topic: fuel filter??? cannot find on form  (Read 4015 times)
same #same#
  • south yorks
  • dont blame me im dyslexic
Re: fuel filter??? cannot find on form
« Reply #15 on: 25 June 2010, 12:33:13 »
Which one in picture
page six opel tool, :y
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #16 on: 25 June 2010, 12:35:28 »
At what mileage should the fuel filter be changed
same #same#
  • south yorks
« Reply #17 on: 25 June 2010, 12:37:35 »
if you dont know when it was put on change it, thinks its 3 - 5 years or 2 years on copys.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #18 on: 25 June 2010, 12:41:04 »
Could you give the part no as I cant find the right picture
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #19 on: 25 June 2010, 12:46:09 »
Sorry I meant the part no for the tool that you copied
same #same#
  • south yorks
« Reply #20 on: 25 June 2010, 12:48:13 »
KL-0121-35 clamp opel tool
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #21 on: 25 June 2010, 12:48:48 »
Thanks
same #same#
  • south yorks
« Reply #22 on: 25 June 2010, 15:15:10 »
just put new one on, and its letting fuel out at both ends, tryed blue seal and that not work is there any other way, old filter is corroded and damaged the rubber seals. any help thanks  :(
same #same#
  • south yorks
« Reply #23 on: 25 June 2010, 16:59:15 »
found how to doit got small huck and pulled out old O-rings and founds some new one's so now fixed no leaks, bent flat head screw driver helps to put new one's back in :y :y
