Author Topic: fuel filter??? cannot find on form  (Read 4009 times)
same #same#
  • south yorks
  • dont blame me im dyslexic
« on: 24 June 2010, 20:17:57 »
how to take the clips off, looked on form but could not find it, thanks for your help.
Re: fuel filter??? cannot find on form
« Reply #1 on: 24 June 2010, 20:20:54 »
i use a couple of small screwdrivers to release the clips and edge it off
« Reply #2 on: 24 June 2010, 20:22:34 »
you need either the correct pliers or three hands. One hand each with a screw driver to hold the tabs in, and third hand to pull the pipe/filter apart....and then watch as the petrol poors directly in your eyes. ::)
same #same#
  • south yorks
« Reply #3 on: 24 June 2010, 20:29:38 »
tryed with screwdrivers and the clips dont budge one seams to be bent the plastic bit, tryed wd and get muck out but wont budge it, have you any pics so can see it, thanks,
« Reply #4 on: 24 June 2010, 20:43:23 »
I messed around with screwdrivers for ages, some would come apart easily some would be a right pain so I spent a few quid on the pliers and its now a 2 minute job. Well worth the money ;)
same #same#
  • south yorks
« Reply #5 on: 24 June 2010, 20:49:06 »
thanks pete, were did you get the pliers from, only have enough space to get one hand in, thanks
Hannah Judes Dad
    • the misses round the bend
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #7 on: 24 June 2010, 20:53:14 »
If you break them they are only 77 pence from Vauxhall Dealer. I am changing my filter at the weekend and bought two new clips with the filter incase I break them. ::) :y
same #same#
  • south yorks
« Reply #8 on: 24 June 2010, 20:58:31 »
did think of that but they are moulded plastic and one is an L shape, both moulded or do you mean the clip part??
same #same#
  • south yorks
« Reply #9 on: 24 June 2010, 20:59:54 »
These are what you are looking for
http://www.machinemart.co.uk/shop/product/details/cht441-3pce-fuel-line-disconnect-set
thank will have a look into them sure must be cheaper if look around.
YZ250
« Reply #10 on: 24 June 2010, 21:29:47 »
I was refering to the plastic clips that hold the fuel pipe on to the fuel filter. :y
I really meant that if you accidentally break one they are cheap enough to replace.
« Last Edit: 24 June 2010, 21:48:52 by Alan-Hearn »
same #same#
  • south yorks
« Reply #11 on: 24 June 2010, 21:47:49 »
just found this PDF opel tool, on page 6, http://www.klann-online.de/Englisch/Produkte/Kapitel_6.2_low.pdf says its a clamp just bit of metal bent, so may just make one has the size etc, as only going to use once or so. here it is so some one else can make one to.
  • Auckland
    • Mazda MPV
« Reply #12 on: 24 June 2010, 22:20:49 »
I don't think the clamp will work because it will be trying to push the clips in from the side. :(
I think you want the set of pliers in the picture above it which push the release ring into the fitting to push the clips out :y
same #same#
  • south yorks
« Reply #13 on: 25 June 2010, 12:17:26 »
did it go old tea straner fixed it to look like one in PDF, came off no problems, just bit worried about the blue O-rings inside the push on(pipe), not put new one on yet is there away of replacing the O-rings or shall I just seal them with blue seal???? thanks
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #14 on: 25 June 2010, 12:29:04 »
Which one in picture
