Author Topic: Air con not cold enough  (Read 1522 times)
Goonybird
  • Northampton
  • Shouldn't have gone to Specsavers
« on: 25 June 2010, 19:27:45 »
Lately my aircon hasn't been as cold as it used to be, even on Lo setting. So I guess it will need regassing.
So do I take it to one of the many purveyors to regas it,
Or do I do it myself, and if so how?
Have owned: Opel Manta A 1900 Auto Berlinetta, Opel Manta B 2.0 Auto Berlinetta, Vx Royale Coupe 2.8 Auto, various non Vx, Skoda Superb 130tdi currently Omega 2.5CDX - now Octavia vRS WRC
Re: Air con not cold enough
« Reply #1 on: 25 June 2010, 19:53:14 »
I'll be changing my condenser shortly (due to a leak), after that I'll take the car to a local specialist - not Quick Fit or the like -  to have the system vacuumed, pressure tested and charged with the correct type and quantity of refrigerant.
On the quantity of fluid required alone, I don't think it's a successful DIY project. :y
« Reply #2 on: 25 June 2010, 21:00:50 »
Den, changed mine yesterday. Instead of disconnecting gearbox cooler pipes @ the rubber hoses I found it a lot easier to undo the torx @ the union block @ the top L/H side of rad and tuck the pipes out of the way but make sure you remove the 2 small O-rings on the "block" at the end of the metal pipes
cmeonthemove
  • Taverham, Norwich
« Reply #3 on: 25 June 2010, 21:46:21 »
I'm with Zulu on this one, or better still get a mobile air-con specialist to come to you and test/vacuum/refill the system. Shouldn't cost any more than Kwik-fitup.
« Last Edit: 25 June 2010, 21:46:44 by cmeonthemove »
Chris
2.5 Elite
« Reply #4 on: 25 June 2010, 21:56:26 »
Per PM Rob, that does make sense - can't wait to get the hands dirty again 8-) :y
